Question about Goodman Heating & Cooling
Have a goodman furnace that is acting like the flame rod is bad. Changed the flame rod and it's doing the same thing. Fires up for 3 to 20 seconds then shuts back down. All wire connections are good, has a good groung, all rollout and limit switches stay closed. Preesure switch stays closed. Thinking it's the circuit board, any other suggestions?
  • cupton68 Sep 19, 2008
    Just happened. Was working fine last winter
    Problem Solver:
  • 5 Answers
Did this just happen and did you change any parts?
Posted on Sep 19, 2008
  • ralph jones Sep 19, 2008
    remove the ground screw and sand where it attaches . sometimes it dose not make a good ground.Verify with a VOM the power going to the module and check all grounds for the circut board.the flame rod picks up ground through the flame , make sure the rod is clean and the flame is blue not yellow tipped.
Goodman furnace furnace starts,flames start and shuts off after 10 sec. Replaced flame sensor still have same problem
if flame sensor is new, the board may not be properly recieving currrent from flame sensor to keep burners on
Feb 05, 2014 | Goodman Heating & Cooling
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
Furnace goes through start up sequence normally, ignitor fire, gas comes on, ignitor goes off, but gas only stays on for about 10 seconds then system restarts all over again.
Not knowing the make or model of your furnace I can only guess that either the flame rod is dirty or bad, the flame spreader tray is dirty or you have a bad ground off of the PC board. You could also have a bad intermittent pilot if your system has one. The flame rod is located in front of the burner at the last one that fires up. It will have only one wire going to it. The flame spreader tray connects each burner together and the gas flows down it.
Mar 12, 2011 | Heating & Cooling
I have a Goodman GMS8 furnace. The unit will start up but then go off so we have no heat. The LED light is not blinking and the rod gets red but then it goes out. What could the problem be?
Does the furnace fire then go out? If it fires then goes out its most likely the the flame sensor. This will be a steel rod that is in the path of the flame when it fires usually opposite end of ignitor. Take this off and clean it with steel wool or very fine sand paper. Make sure to pick the right part, the part that glows red is your hot surface ignitor and should never be touched as the grease on our fingers will react with the silicade nitrade and cause failure.
Dec 13, 2010 | Goodman GMS90703BXA Heater
After the thermostat is switched on the furnace fires up but will not stay on and keeps recycling
take out the flame rod at the end of the burner assembly and gently wipe it down with a scotch brite pad and reinstall. This should tell the board that there is a flame established and it should stay on. If this doesnt work, the flame rod will need replaced
Jan 24, 2010 | Goodman GMS90703BXA Heater
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
GOODMAN GAS FURNACE. IGNITOR GLOWS, GAS FIRES FOR 3-4 SECONDS THEN SHUTS OFF..CYCLES OVER AND OVER. SOMETIMES IT STAYS ON...THEN SHUTS OFF BEFORE TEMPERATURE GETS UP TO THE STAT SETTING...
I suspect that the flame is not traveling to all the burners within a given time so the flame sensor is shuting down the gas valve. Clean out the flame rail where the flame travels and carefully brush off the flame rod with an old tooth brush.
Oct 19, 2009 | Goodman GMS90703BXA Heater
Furnace starts properly, then shuts down, led flashes 8 times
The first thing to look at is the flame sense rod.
Shut off power to the furnace, remove, clean sensor with steel wool or sandpaper then reinstall the sensor. Reapply power and it should run properly.
Jan 10, 2009 | Goodman GMS90703BXA Heater
Furance lights and goes out after ten seconds does this three times.bought a new flame sensor worked two days same thing again.goodman furnace
If it isnt the flame sensor make sure the furnace ground wire is hooked up.If the ground is bad it cant sense flame.
Oct 20, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
