Sharp LC26D40U Blank screen
I have a Sharp LC26D40U LCD TV that we bought July 2006.
When we switch it on the green light comes on and we get sound but no picture. Just a totally blank screen irrespective of channel / Input.
I heard that Sharp released a bulletin on this issue and wondered whether this is correct / whether there is any hope?
Thank you for any help that you can provide
  • 1 more comment
  • neil1999 Sep 22, 2008
    Thanks Shinayo1 for your help - would this be the Sharp Back Light Inverter (VIT79005.51) or is it a different power Inverter?
    Thanks again so much for any advice you can provide.
  • neil1999 Oct 03, 2008
    shinayo1 - Thank you so much!
    I bought a Sharp Back Light Inverter (VIT79005.51) from shopjimmy on the web for $79.95 + shipping.
    It arrived yesterday and I installed it last night and it Fixed the problem. Fantastic!
    I had to remove the back and front cover, metal hardware that attaches to the back bracket area. Also had to disconnect a grounding wire where it attaches to the metal back bracket. Then I had to remove one speaker and also a small connector that powers the front power light. Then removed the main board and the big metal enclosure that the LCD Panel is in. Opened that by undoing the screws that are on the edges (not the ones on the front. You are then able to lift the front of the LCD metal enclosure away from the back plate of the Panel enclosure. That gave me access to the Inverter which is on the righthand side of that back plate. I had to twist the lcd panel around by 90 degrees to access the inverter (there are a whole bunch of wires that leave the center of the LCD Panel and connect to the center of the component board on the back plate of the enclosure. Switching the inverter was the easiest bit. A few very small phillips screws and then some plastic connectors to gently prise open.
    The trickiest thing was remembering which screws went where - so each time I unscrewed one I would then stick it with sellotape to the place thet I removed it to ensure i remembered where I took it from.
  • gururu2 Mar 19, 2009
    Our LC26D40U/LC32D40U model Sharp Aquos goes on fine, but within a few minutes, the screen goes blank, sound stays on. We thought it was a problem with our satellite provider. However, after exhausting all avenues with regard to the satellite service, we took the TV to a local authorized Sharp repair shop. They told us we needed a new display that would cost $1,100.
    This TV was a gift, so we are not out any money, but we certainly wouldn't buy a Sharp brand to replace it.
This comment is for those of you who are handy with a soldering iron. I had this problem and found the component on the backlight inverter board that failed. It is a tiny, 3-cent, surface-mount fuse; probably some type of poly-fuse or, perhaps, a thermal fuse. The fuse is black and about the size of an ant, and the marking on the pcb near it is "F1", while the marking on the fuse itself is "20". I removed the bad fuse with my soldering iron, but since I could not determine the exact replacement for the fuse, I decided to replace it with a small 1-Amp fast blow fuse by soldering the leads onto the 2 surface-mount pads. I figured that even if I could find the exact replacement for the fuse I wouldn't want to have to replace it again in a couple of years. You should be able find a suitible small pcb-mount fuse at an electronics store such as RadioShack for around $1. If not, there is always DigiKey on the web. Hope this helps you.
Posted on Jul 22, 2009
  • rileyporter
    rileyporter Jul 12, 2012
    To be clear the inverter board for this TV is located between the screen and the back PCB. What I mean is you really have to take apart everything to get to the "inside" of the metal box. You will see a bunch of BLUE and PINK wires with connectors that plug into the inverter board. Also, you will see a black plastic / rubbery "cage" that is glued to the board. I had to remove this to find the fuse. However its pretty easy to get to when you know where to look. The fuse has a 20 on it like stevem314 said. However, its placement is almost directly "upstream" of the white ribbon connector. Just follow the connector leads up a bit and you will find it. To be clear the inverter board is high voltage. Caution should be observed when messing with it.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Chage the inverter
Posted on Sep 21, 2008
  • olayoju victor Sep 29, 2008
    yes, i really mean your backlight inverter.
Thanks for your appreciation
Posted on Oct 05, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have a sharp 26" tv that displays a please wait. do you know whats wrong?
Part called DIGITAL UNIT has failed and require replacement, You probably talking about LC26SH20U or LC26D40U?
Oct 31, 2009 | Sharp AQUOS LC-45D40U 45 in. LCD...
Sharp LCD screen is blank when switched on
complain to sharp---same problem--thats what i'm doing
Aug 20, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp lcd screens are very easly damaged especially the larger screens,this could be at fault even though it looks ok,try shinning a light on the screen and checking every inch,could be the internal screen that has damage hence why not powering up.
Failing that it sounds like an internal short.
Apr 20, 2008 | Televison & Video
Astar 32 in LCD
Have check internal power board? any way just call me at
323-767-6030 I will help you go through as much as I can to power up your tv.
Feb 09, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Televison & Video Logo
747 people viewed this question
Top Televison & Video Experts
