Konica Minolta magicolor 2300DL Laser Printer
Problem for Konica Minolta magicolor 2300DL Laser Printer
Paper jam
By rshekh on Sep 19, 2008
The display on the printer says MEDIA JAM - TRANSFER ROLLER. The paper gets folded over within the printer and nothing gets printed.
Same Problem
Feb 10, 2009
-   My 2300DL was working fine before it sat idle for several months during a remodeling project. Back on-line, it developed the same problem. Either I get a paper jam transfer roller error (and have to open the machine to pull out the jammed sheet) or the page comes out with a very neat horizontal fold about 1/3 of the way from the top of the page.
I've tried to ideas here, and they haven't helped. Has anyone had better luck?-   Guest
Sep 20, 2008
-   As described above the paper comes out folded. When I press down in the paper tray several times as described that works for the next sheet of paper then I get a load paper error message. When I open the tray and push down again the next sheet will print but then the same load paper message comes up. This just keeps repeating. If I feed the paper from the left side tray it jams with multiple accordian pleats and I get a paper jam at transfer roller error. Are these related or separate problems? Any other suggestions. I've tried cleanning everything I can reach without totally dismantling the machine. -   patjg
Best Solution
posted on Oct 12, 2008
Helpful)
zigy_dk
Rank: Apprentice
Rating: 85%, 1 votes
I had this exact problem, but pressing the tray down did not help... But i was on to something. There must be a sensor there, so i tried to blow some air down under the plastic, if some dust should have entered. And then it went like a charm. Kristian
Was this helpful?
Yes
No
Solution #2
posted on Sep 19, 2008
Somewhat Helpful)
soumyak
Rank: Wiz
Rating: 72%, 31 votes
take out all the paper from the loading tray, and press down on the inside of the tray 4 or 5 times, and put a sheet back in. There seems to be a physical irregularity with all 2300DL printers that causes this problem
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Nov 05, 2009
Very Helpful)
robfarmer
Rank: Apprentice
Rating: 100%, 1 votes
I same problem.. I hadn't used my one i months. tried printing and would only feed the paper in and make folded paper inside.
I fixed it by the damp cloth on the feeder roller. Not the bottom roller but the main one in the middle. I had to roll the roller abit. when I was rolling it it had fluff come through from the main roller that touches the drum. So roll the middle roller with your fingers and wipe.. keep doing it as it's rolling the the larger main one. will take a while until you get all the dust and fluff out!
Was this helpful?
Yes
No
Popular Solutions for Konica Minolta magicolor
Questions and Unsolved Problems for Konica Minolta magicolor
Do you recommend Konica Minolta magicolor 2300DL Laser Printer?
Answer
Answer
Just replaced the drum because I was getting vertical striping on the left side and I'm still... (More)
Answer
What appears bright blue on the screen is coming out a purple sort of colour on the paper. Any... (More)
Answer
Setup completed but which port should be used? Using windows XP Original user was directly connected... (More)
Answer
need driver of magicolor 2300dl to computer 64 process
Answer
black (and sometimes yellow) bar on print page 1 following a label getting stuck in machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Konica Minolta magicolor...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
