Question about Panasonic KX-T7453 Corded Phone
D1232 extension programming issue
Hi... I've done phone admin before but not on a d1232 & a KX-T7453... I'd like to change the extension # on the phone at my desk. Its currently ext #225. I'd like to change it to #210 which is an extention that is not currently assigned to a phone but just goes to VM. I went to ext 101 (manager -admin phon) and did the stuff related to programing "Extention Number" (code 003) but the system doesn't seem to accept it and gives me three beeps instead of one when I hit store. Any suggestions?
Brian
  • 2 more comments
  • BKLLC Oct 26, 2008
    thx!... I did get this done... I have a new issue... when calling in from the outside and receiving the auto attendant there is a particular extention (224) that if you spell by name or just dial it the system comes back and says "Sorry no one is available to answer the call...." (it does give you the option to press 1 and leave a message which does work)
    The extention can be dialed from another extention... if you dial it with the FWD light on the phone flashing the call will go directly to VM. If you dial it with the FWD button off the extention will ring.
    I checked the management settings in the VM system, its not set to forward all calls and that would result in it going to voicemail anyway which its not.
    Why can't I get to it from the auto attendant? I've tried to cancel everything I could think of...
    HELP
    Hi thx for the quick reply... extention 224 does already have a greeting recorded... if you call it from another extention and the FWD light on that extention is flashing (on) then the call goes to VM and the persons greeting is played....
    more info: it actually says "their is no one available to answer the call" then it gives you the option of pressing 1 to leave a message or 0 for the attendant... if you press the 1 you do get the VM greeting... so the issue is that when coming in on the auto attendant the attendant never trys to ring the extention
  • Panasonic Master
  • 2,460 Answers
Welcome to Panasonic TD programming....
Even though the hardware doesn't exist, the numbers do. The universe of 101-164 and 201-264 are already taken. Oops, 200 might be available, 100 might be available. 167 and 168 and the 80's might work.
It's a 3 step process. Change 210 to 200 change 225 to 210 and change 200 to 225. There's your "swap".
Now, keep in mind that the XDP port for 110 is 210 and if your voice mail is analog.....Ah, but that's another thread.
Carl
Posted on Sep 19, 2008
  • Carl Navarro
    Carl Navarro Oct 26, 2008
    First of all, please rate the last solution.
    The "sorry there is no one to take the call" is a system greeting that is played when there is no greeting recorded. From anywhere, you can call the voice mail port(probably 165) and dial #6 *224 and the password, if it's set. Option 5 gives you the prompts to change/record the greeting and user name.
    Start with those things first. There is the odd possibility that your VM is old, or you have something funny set in the options, but this will probably fix it.
    Hope this helps....
    Carl
How to reset or know Panasonic KX-TD1232 Admin Password without loosing existing settings and programming.
On the D1232 box open the main door and there is a switch front lower right (normal - clear)... switch to clear and go to the main or number one phone and hit program *# ******* (7 stars should do it)
once your logged in hit 107 and then next to view current password
once you have the password you can switch it back to normal and log in with that password by hitting Program *# (password)
Mar 27, 2010 | Panasonic Lands Phones
Pulsating Phone
An expansion card is 8 ports. It's possible that the 6 phones are on the same card and that there is trouble on one of the data pairs. Try to determine if the phones are grouped together by extension as in 117-124 or 125-132 and start disconnecting them at the phone system.
You'll probably find a bad jack, water, or a different phone plugged into one of the 8 ports that is causing the trouble.
Carl
May 20, 2009 | Panasonic KX-T7433B Corded Phone
I'd like a (relatively) simple answering machine for d1232.
I can get you there, but you have to do some programming.
A Panasonic TD-1232 starts its life with 16 analog and 16 digital ports. On the back of your digital phone is a modular jack called an XDP If you plug in a single line device and dial 390 from the digital set, and it's programmed, you will split the extensions to whatever your number is and 100 more than your number (by default). So, if you're 110, the XDP analog port is 210.
Once you get that far, it's a (fairly) simple matter to go into programming and make 10-2 (the second port for your hardware) ring on any and all lines you choose.
I hope this is a good start, as full programming is beyond the scope of a free forum.
Carl
Apr 08, 2009 | Panasonic Lands Phones
How many stations can a Panasonic D1232 support?
If it says D1232 on the box, it's a TD-1232. Look at the black and silver tag on the side of the KSU, IIRC the TD-1232's tag is on the lower right outside above the power cord. Three is a TA-1232 a TD-1232, and a 123210/11. Only the TD is digital (uses 72xx/74xx phones).
As far as SYSTEM phones, the TA/TD 1232 come out of the box as 8x16 devices and you add cards to expand it. These cards have -70 part numbers and are fairly difficult to find. (I think I have one or two on my shelf). If you really have a 123211, it also expands by using cards, that fit vertically in the card file with an AMP connector plugged into its face. Those are easier to find, the risk there is when you turn off the system to install them, it sometimes forgets to power back up.
Lastly, if you really have a TD with digital phones, there is an ANALOG port on the back of each digital phone that can be wired for seperate extensions (by default it's 100 more than the digital extension). You can add single line devices in those ports.(Some restrictions apply :-). For two quick phones, you might go that route.
Carl
Feb 28, 2009 | Panasonic KX-T7453 Corded Phone
I can't make a call more then 6 digits on our PBX D1232 pls help
You obviously need to change the system programming to allow you to dial more than 6 digits. If you are not the system administrator, then talk to him/her.
Feb 24, 2009 | Panasonic KX-T7453 Corded Phone
D1232 Panasonic - Removing Long distance restriction
Changing the Class of Service COS of that extension to "1" will allow it to dial anything.
In a TD system, that is a 2-step process, because you have to find where the extenion jack is located in the system.
Go into programming and dial 003. If you press the SP PHONE button, it will step you through all the ports in the system and give you extension numbers. To start 01-1 will be 101 01-2 201 02-1 102 etc. Since you're in a motel, it should be renumbered to match the rooms and if you started with 100 or eliminated 113 your whole plan may be different.
Once you find the jack number for your station, press the HOLD button and dial 601 SP PHONE and the 2 digit jack number from above. You will be looking at your extension COS. Dial 1 STORE and it will turn off that extension's toll restrictions.
Please rate this solution and let me know if you had any problems following this instructions.
Carl
Dec 11, 2008 | Panasonic KX-T7453 Corded Phone
KX-T7453 co light will not light when someone is on the phone
I don't know what instructions you have, but try these.
Press PROGRAM 99 and the button you want to program
Dial 1 plus the extension number and STORE.
Was that what you were doing?
Carl
Aug 21, 2008 | Panasonic KX-T7453 Corded Phone
7453 Display
Without looking up details on versions, I think you may have an early D1232. Look at the plate on lower edge/front and see if there is a number in a circle. If there is no version number, the serial number will tell when the system was made.
Jul 07, 2008 | Panasonic KX-T7453 Corded Phone
Expanding phone system
We have existing Ativa Model # D5772 & just purchased a 2nd model How do we connect the 2 systems?
Dec 12, 2007 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
685 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
