Question about Toshiba Satellite A215-S4747 Notebook
ASKING 4 HELP
Hi my fan is not working and it[A205] keep suting down
    Novelist:
  • 157 Answers
Yaseen-
Sorry to hear about your problem but I urge you- DO NOT continue to use this laptop knowing the fan is not working. While it may not be ideal, you can purchase a new fan and install it yourself fairly easily for under $100 (or have someone at a local computer shop do so) but please understand that the reason it keeps shutting down is a security measure to prevent vital damage to the really expensive hardware components.
Here is a link to a power supply for your laptop if you choose to replace is yourself:
Link to fan
Posted on Nov 30, 2008
My Toshiba satellite A205-S5804 laptop keeps losing power randomly with battery at full and the AC cord plugged into it. I also have a external fan unit to keep the laptop cool but to no avail. What could...
get the download core temp off cnet.com
download and install then run it
watch your cpu core temperature
set a warning in the core temp features to alert by alarm when the temp gets above say 80 C
if it hits 80C.. its running too hot
Jan 21, 2011 | Toshiba Satellite A205-S5804 Notebook
Toshiba Satellite a205 the battery light started
I think you may need a new power supply, check this to make sure it is working OK, If this isn't working then the battery will not charge, and give symptoms you describe.
Feb 20, 2010 | Toshiba Satellite A105 Notebook
Just ramdomly powers down
Hi
Thank you for query
Please try the following
1) Switch the laptop on
2) When you switch it on there will be a message advisig to press esc or F12 to go into setup, if this is not there then try pressing F12, esc or the del key
3) This will take you to a blue bios screen
4) leave the laptop in this mode and see if it powers down
If it does you are having a issue with the laptop overheating, it may be the vent is blocked or possibly the heatsink (Fan that sits on top of the CPU) is not working
If it does not cut out you know you have a software issue and this is probably best resolved by a full reformat
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank You again
Feb 12, 2010 | Toshiba Satellite A205-S4617 Notebook
Toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Aug 18, 2009 | Toshiba Satellite A205-S4617 Notebook
I want to change the 2 x 512DDR ram by 2x 2GB DDR ram memories in my A205-S4577/Toshiba. Will it work?
hi,
it will work as your notebook is supporting maximum 4 gb RAM but please check that you are using 32 bit operating system or 64 bit one.
If it is 32 bit then the system will be showing 3.2 gb RAM only as this is the 32 bit os limitation.
Jun 03, 2009 | Toshiba Satellite A205-S4587 Notebook
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
It crashed and now it automatically shutdown after a minute about
The fan may be cluttered with dust. Clean it. Then turn the unit on and watch to see if the fan does indeeed work. If it does not, shut the unit down till you get a replacement fan. The fact that the unit shuts down is a saftey feature to keep your Proceesor from being damaged.
If cleaning it works, your processor should be ok.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 13, 2009 | Toshiba Satellite A205-S5879 Laptop
I want to reboot my Toshiba A200 back to factory settings, i have a spyware down load **** that keeps on asking me to install.....how do i reboot
If you have the recovery CD, then put that in the drive, reboot the laptop and make sure you boot to the CD. The recovery process will start up and you can restore the laptop to it's factory settings. Make sure you have all of your documents, music, etc. backed up.
Dec 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Nokia 6070 Security Code
GO TO RESTORE DEFAULTS IN SETINGS AND RESTORE EVERYTHING AND U WIL GET A DEFAULT SECURITY CODE 12345...
Aug 14, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Toshiba Satellite A215-S4747 Notebook Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
