Question about Canon ZR200 Mini DV Digital Camcorder
Misplaced manual for my Cannon ZR200 Digital Video Camcorder
Could I get a new manual for my Cannon ZR200 Digital Video Camcorder sent to me?
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
ZR200
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 19, 2008
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
I Have a Cannon XR 200 A. When I load the tape, it takes it in then beeps twice and reject the tape. What can I do to solve this problem?
Ahh Are you sure the tape is compatible?check tape compatibility..That happen sometimes if its not compatible..
Dec 28, 2010 | Canon ZR200 Mini DV Digital Camcorder
How do u delete stuff on ur cannon zr200
There is no delete function as such for video tape. You just record over it.
Dec 12, 2010 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 mini DV Digital camcorder power is not coming.
First thing, clean your battery contacts, both on the battery, and on the camcorder. Make sure the battery is charged fully (measure it if you have a voltmeter). Make sure your power adapter is putting out voltage (again, measure it if you can) Try a spare battery, if you have one, to make sure the first one isn't just dead. Other than those things, you could have a faulty or broken power switch on the unit. That's about all I can think of offhand.
Apr 12, 2010 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
I can record and see it recording but i can not view my recording. At first the tape wouldnt eject but i was online and i went to troubleshoot for the cannon mini dv camcorder zr200 and it told me to tap...
1. Connect the camcorder to a TV and check if you can playsee the tape.
2. Take that tape and check it using another miniDV camcorder.
this way you will know if the issue is within the camcorder or the tape.
If is within the camcorder .. take it to a service dealer and see how much is to fix it. Chances are that is not worth to be fix. A brand new ZR900 is just 200 USD ...
Dec 23, 2008 | Canon ZR200 Mini DV Digital Camcorder
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=326&modelid=11004
Nov 22, 2008 | Canon ZR200 Mini DV Digital Camcorder
Downloading video from Canon DV zr200
purchase a 4 pin to 6 pin firewire cable and mac should recognize camcorder-that should be about all you need to do-older cam so maybe go to cannons website if problemd with drivers
Jul 01, 2008 | Canon ZR200 Mini DV Digital Camcorder
Gray Lines
What do you mean by "Its only when i go to record or view previous recording"? in what situation doesn't it show the gray lines? What about the viewfinder? do you get lines there aswell? If you don't see the gray lines when you transfer the video out of the camera, then you don't have a head problem, a screen problem maybe. Don't hurry to use cleaner tapes because they can hurt the head, the actual cleaning procedure is one that scrapes the head and leaves some damage. more info please
Jun 10, 2006 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
237 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
