Question about Whirlpool Duet GHW9150P Front Load Washer
F-06 error code
I have been having a problem with F-06 error coe for some time now, multiple techs have checked it. once they changed the entire drum assembly because of a broken shock, i recently replaced the belt and the mcu as advised by the tech but i still get the code. what can this be
  • 5 more comments
  • adrian33 Sep 22, 2008
    i am sorry it was the ccu i replaced, just slide the top off and replaced it the tech i had out here told me that was the problem and that i needed to replace it. after i replaced it i ran thru the test sequence and it went thru all the testing. where before i replaced that it would not go thru the test fully.
  • mfhay7 Sep 22, 2008
    I have the same F 06 error message. I have a whirlpool duet bought in 2006 for a summer home, so it only is used in the summer.   I called whirlpool and they referred me to Jersey Coast Appliance. The authorized mechanic was out 3 times to a tune of $300 (I could have bought half a washing machine).  He said it was the shocks but when he replaced the (unworn shocks) the problem stayed. Now he says it is a wiring problem that will cost another couple hundred dollars.
    I am reluctant  to throw any more money into this machine and Whirlpool will not stand behind their product.  Any thoughts?
    wish i had a solution for you i am still having problems with it if you dont use it for a couple of days you can wash two loads or so, but if used everyday it will not spin the drum out and F-06 will start flashing.
  • mlak Sep 24, 2008
    I'm having the same problem, Have taken the back cover off and checke the wiring on the motor and mcu. It worked a couple of cycles and starts with the F-06 code. I'm gona plunder some more
  • bob4320 Dec 02, 2008
    I had the same problem. F-06 started after the second load. Turned off the breaker to re-boot and it worked for one load then F-06 again. Called A&E factory repair and they were no help. First visit was $120 and they couldn't fix it. Second A&E guy said CCU was bad. He wanted $700 for the repair and service charge ($500 for the CCU alone). I called Whirlpool and after arguing for a while they said they would send me a CCU for $150 but I never could get them to send one so I bought one online for $250. Got the CCU and installed it but still got the F-06. Then decided to change out the MCU ($150) based on another post on this site. Did that today and the problem is fixed. If you have the F-06 problem, suggest starting with the MCU as it is cheaper and most probably the problem before the CCU.
  • adrian33 Dec 02, 2008
    I HAVE FIXED IT CHANGED OUT THE MCU AND ALL IS WELL BEEN WORKING ABOUT 1 MONTH. THANKS FOR ALL THE HELP. Adrian
  • nikkirock Mar 07, 2009
    My wife and I bought a Whirlpool duet front loader in 2005. About a year and a half ago we got the F-06 code at every wash. Whirlpool brushed us off after several calls and wouldn't renew the warranty I bought from lowe's when new. (i know why now). A tech came out and said it is the control panel. After reading these posts here, i'm about sure it is the MCU. I'm going to replace it and see and if it works, i'll be sure to post that here.
    Problem Solver:
  • 17 Answers
Yes an F06 is the MCU, F11 99% of the time is CCU.
Posted on Mar 08, 2009
The solution is replacing the MCU. I had the same problem. Would work for a load or two and then F-06 error code. I had A&E factory service out twice. First time he charged me $120 and couldn't get it to repeat the F-06 error. After he left, we did two loads and got F-06 again. Second techician from A&E said it was the CCU and wanted $700 to repair ($500 for the part and $200 for labor). I decided to do it myself and bought a CCU online for $250. Installed it and still had the F-06 problem. Then I installed the MCU for $150 based on other comments on this site and that was the solution. Haven't had any F-06 errors since. If you have the same problem, suggest you try replacing the MCU (Motor Control Unit.)
Posted on Dec 02, 2008
I GUESS NOT BUY WHIRLPOOL
Posted on Sep 26, 2008
I had the same F06 error and some other symthems, replace the mcu and the unit is up and running fine. Easy to change out once I figured out how to take off the front lower panel
Posted on Sep 24, 2008
  • mlak Sep 26, 2008
    I live along the Gulf Coast In Ms, and we had a lot of power outages due to the 2 recient storms that his Louisana and Texas. The guy at the appliance store said they have had a lot of calls with appliance problems and replacing electrical parts. The MCU, motor control unit was bad on our Whirlpool 9400. I had the dreaded F06 code . If I unplugged the washer and let it sit for several hr, it may finish one load and then the F06 code would show up. After reading several comments from other people having the same problem and the mcu seemed to the culpret, decide to take the plunge and change it out. Washer works great now and has completed about 6 to 8 loads since the mcu has been replaced. Once I figured out how to take the from lower panel off, change out was a breeze. The MCU is located just to the left and in front of the motor if you are facing the front of the washer.
    Genius:
  • 1,028 Answers
Ck all wiring connections from motor to motor control to main control on top rear rail f06 means main control can't detect motor speed when you say mcu i assume you mean the motor control bd next to motor they and the motor both have given very few problems in our area i suspect the ccu (central control unit) is the most likely cause
Posted on Sep 20, 2008
Error code F 06
Hope this helps... I found it on an appliance blog that I go to from time to time.
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
Feb 14, 2015 | Whirlpool WFC7500VW Washer
Changed drum, still show drum error
Is it an OEM cartridge or a refill? Once you changed the cartridge, did you reset the counter? What error code is it reporting? All of these items have to be considered. The biggies are if it's an OEM or not, and the exact error code it's displaying.
Oct 16, 2014 | Brother MFC-7340 All-In-One Laser Printer
Gives code F15, drum motor not working. Does fill and drain ok. Have unplugged and changed cycle with no change, drum motor not working. IS there a reset?
F15 is a motor control unit error, this can be caused by a module failure or loose wiring or multiple error codes in a cycle, try un plugging for ten minutes to reset.
Aug 17, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Jun 25, 2011 | Canon imageRUNNER C3200 Copier
Code f 06 - washer will start to run for 2 minutes then stop and beep with code F 06
"F6" is a Motor Speed error problem. It is commonly attributed to either a broken or slipped drive belt, defective Drive Motor, bad Motor Control Unit (MCU), or the interconnecting wiring. The following link explains:
http://www.fixya.com/support/r3608706-f06_error_code
First, remove the back panel of the unit and make sure the drive belt is not broken, or has not slipped off the drum pulley.
Then, remove the top panel of the washer and check all the connector plugs between the Drive Motor, MCU and Central Control Unit (CCU). Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact. The top panel comes off by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
The MCU has a tachometer mounted on it. If it is determined to be the cause of the problem, it is considered part of the MCU and cannot be replaced separately. The MCU is not serviceable and will require replacement.
Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. You should not need a service manual because each one of these washers comes with a technical data sheet.
For more in depth troubleshooting tips refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Mar 11, 2010 | Washing Machines
Two weeks ago I saw on Fixya service that my error code E000020-02b0 was a Magenta drum. I replace it this week and ran the printer about 400 copies then the unit stopped and a new code (almost the same)...
There are sensors just underneath that may be covered in excess toner waste. I tend to see that a lot when the company i worked for did canon machines.
Nov 16, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C4080i
The drum will either produce an error code of E000020 with multiple subcodes. This is time to change it. Also if your getting weak density or solid backgrounding of a particular color. These are all ques to change the drum.
Feb 05, 2009 | Canon iRC3100 Printer
Sub zero 700 TR error code 06
Error code six means: from SZ
Refrig. evaporator thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
Erratic temp can be many things such as an open door. Clear the code by holding the bell key for 15-30 seconds or until you hear a tone. Keep an eye on your temps for a couple of days. If it comes back its time to call a service tech. If you are in OC I have the number of the best tech for Sub Zero in all of SoCal. There is more tests that can be done depending on how tech savvy you are.
Jan 21, 2009 | Sub-Zero 700TR
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Sharp AR-M280U
Hi:
L6-10 will be a polygon mirror motor error, (a multi-sided mirror that rotates in a similar way as a hard drive spins. writes laser data to the drum) .When this code comes up it usually indicates that the motor is locked. You will need a new polygon motor , most techs would change the entire laser unit.
Sorry but It will have to be serviced professionally.
Jan 18, 2008 | Sharp AR-M280U Grayscale Copier
Whirlpool Duet GHW9150P Front Load Washer Logo
894 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
