Question about Panasonic Lumix DMC-LZ7 Digital Camera
Taking apart a Lumix lens
I wonder if you have any tips on taking apart a Lumix lens. I was inspired by one of your posts about taking apart a camera with a stuck lens, and mine is now in pieces, but I can't quite get to where I think the sand might be making the lens stick, and I wonder if you have any suggestions. I have the cylindrical lens part detached from the rest of the camera, but the black plastic casing seems to be attached to the rest of the lens without screws for me to undo.
Thanks for any help!
  • 298 Answers
SOURCE: replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Posted on Mar 26, 2008
  • 98 Answers
SOURCE: Stuck Lens
It seems that the lens is stuck.
If you can repair it i have the repair manual, if not i can repair this problem, I'm not shure if i allowed to send our repairadress in the Netherlands we replaced a few gears or repair the damage into the lensunit.
Posted on Apr 05, 2009
vortash
  • 431 Answers
SOURCE: panasonic lumix dmc-lz7 lens barrel doesn't move
Hi Sarah I am Vortash it shouldnt need to be a new camera a good clean out by an engineer should cure the problem provided you havent tried to force the lens back in if it was out , he will clean it with white spirit or alchahol and re set the lens mechanism and it shuold be fine .. but get an estimate first as the economics may be in favour of a new camera if it would cost too much .. in the uk here we charge approx $25 for that but it may be more over the pond .. regards Vortash
Posted on May 31, 2009
dlundmark
  • 797 Answers
SOURCE: I dropped my camera, the lens cover is stuck open
To fix the lens is probably not your kind of work, and now you may be better to sell this camera for parts on a site like Ebay.
Not a good idea to try to fix it.
Posted on Sep 11, 2009
Testimonial: "Thanks for the help! The lens cover is stuck open,and so far the pictures "seem" sharp. previously Idropped my CanonSX110 and it got slightly blurry"
JULIANFIX
  • 975 Answers
SOURCE: I think some dust or sand has gotten in the zoom,
RIGHT !! before taking it to the camera shop , try some COMPRESSED AIR , NOTHING ELSE YOU CAN DO . THANKS AJ
Posted on Nov 30, 2009
Similar problem -Error message Remove Lens Cap and press button.
After reading di_nick34 solution about removing sand, I removed the lens hood adaptor, and blew air between the gap, re-screw adaptor on. Heard a few clicks - must have broken some minute dust/dirt. Remove hood again, and further blowing. Must have removed the dirt stuck in the gap. Camera now works fine. Hope others with similar problem waill have same success.
Sep 12, 2009 | Panasonic Lumix DMC-FZ8 Digital Camera
Overexposure, Underexposure
Try this:
12-29-2007, 10:17 AM epuronen user_offline.gif vbmenu_register("postmenu_274670", true); Junior Member Join Date: Dec 2007 Posts: 1 icon1.gif Lumix TZ1 problem with flash I have experienced problems when using my Lumix TZ1 with flash. The pictures are often too dark but sometimes too light. I have now found a work-around for this problem. It consists of doing the following:
* set the sensitivity to ISO 100
* set the flash to "A"
* take a picture with the lens cap on
* remove the lense cap and take your pictures - they should come out fine
I don't know why this works but I think that when the TZ1 does not have enough information to compute a shot, it will rely on information from previous shots. Taking a picture with the lens cap on may reset the information in the camera so that it does not rely on previous shots. Setting the ISO to 100 will prevent the over exposed shots as the software may sometimes choose ISO 400
Dec 29, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Lumix dmc lx2
Does the menu show up on the screen, or is it totally black?
Does the camera take pictures and behaves as normal (apart from black screen ;)?
If the menu shows up then I'm afraid it's most probably something serious- like dead CCD or failed shutter (probably the latter-LX2s are not famous for failing CCDs). Failed shutter is easy to identify. You would normally hear a faint mechanical"click" when taking a picture (make sure you disable sounds in your camera). If you can't hear anything then the shutter might be dead. In cases like this I normally suggest getting a donor camera from ebay and replacing the lens (the shutter assembly is inside the lens but it's much easier to replace the whole lens).
Good luck,
Raf
Aug 04, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Lumix DMCFZ8
I had the same problem after dropping the camera. In my case, the lens became jammed. Of course your problem may be due to something else. In my case, I disassembed the camera and reassembled it and it now works fine. It was a bit time-consuming to do, but is possible.
I used these instructions, although they are for a somewhat different model. http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
In the case of the FZ5, some people reported being able to get the lens to work by manipulating the lens without taking the camera apart. This might work if the cog inside has slipped off of it's track. In that case it might be possible to work it back into place. If the cog is intact, though, forcing the lens might damage it.
May 10, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Remove lens cap
did you find a way to fix this problem? i am dealing with the same issue.
Mar 19, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Dec 31, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Canon S80 lens won't retract
I have the same camera and had this problems today. My son solved the problem for me. He put his thumbs on each side of the lens and pressed inwards causing the lens to pop out. Since then, I have been able to close and open the lens repeatedly without any problem. Hope this works for you. Good Luck!
Syed
Nov 29, 2007 | Canon PowerShot S80 Digital Camera
For some reason my camera keeps comming up with a "REMOVE LENS CAP AND PRESS > BUTTON" error but the lens cap isn't on the camera :(
it sounds like the lens barrel is out out alignment. Possible the barrel was stuck while it was extended. There is a sensor on the lens barrel asemmbly that must be in the correct position after the camera is turned off. If this doesn't happen then you will get this message..at least this is what I have experienced in my repairs on this camera
Aug 22, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Lens scrunched
Yea, I'm guessing this is not a do it yourself'r kinda project. As for taking camera stuff apart it requires tiny screw drivers. Sometimes small pointy pen/pocket knife blades work. But you're more than likely going to strip the heads out. Over the eons, I have taken some cameras apart, but confess that I've never put them back together again.
Apr 25, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-LZ7 Digital Camera Logo
198 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
