Question about HP 1040 Plain Paper Inkjet Fax
Beeping handset beeps several times when picked up
  • 2,120 Answers
No dial tone detected.
Posted on Sep 26, 2008
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
Instruction manual for binatone telephone model 1...
the phone has started beeping - it beeps within 15 seconds of me picking up the handset to answer a call / make a call - any ideas?
May 16, 2010 | Cell Phones
How to find a handset phone?
Just use the pager button on the base and listen for the ring on the phone. It will either beep or ring. If it is like mine you will have walked by it several times at least.
Mar 23, 2010 | Uniden TCX905 Cordless Expansion Handset
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
Phone dialing problem
I had to switch the spy prevention function (IPP) off
Jan 10, 2009 | Lands Phones
GN 9120 beeps constantly
Are you using the GN1000 Handset Lifter? And if so, are you playing music/radio through the speaker of your telephone? If this is the case the Lifter will be picking up the sound of the music coming from the telephone and interpreting it as an incoming call, hence sending a signal to the earpiece in the form of beeps. Just stop the music coming from the telephone and the beeps should stop.
If you are not playing music through the telephone, you may need to turn down the sensitivity adjustment on the back of the Lifter. Just turn the knob anti-clockwise a little bit and see if that eliminates the beeping. If the sensitivity adjustment is too high it will pick up every little noise that goes on around your desk and interpet them as the phone ringing.
If you are not using the GN1000 Handset Lifter, then the beeping may be the result of a sticking/stuck volume button on the earpiece. If you adjust the volume on the GN9120 it gives a beep when you reach the maximum or minimum volume. If a button is stuck down it will result in a constant beeping. A stuck button is generally not a user servicable problem, however a little bit of tinkering with the button may get it unstuck.
Nov 19, 2008 | GN Netcom GN 9120 Professional Headset
GN Netcom 9120 unexplained beeping
Actually what she was hearing was the ring tone in her headset when a incoming call comes in. The sensitivity on the handset lifter that picks up the ringing on a incoming call was set all the way up and was picking up interferance from the headset base as they have the tendency to buzz when placed right next to the phone. I just turned down the ringer sensitivity with the adjustment on the handset lifter and that took care of the problem. Thanks for your time.
Nov 06, 2008 | GN Netcom (9120-48) Wireless Headset
No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
Jun 23, 2008 | NTL VS1500 Cordless Phone
RCA 4 line phone
Hi Richman,
If you have more than one phone line which I assume that you do -if one party has not completely hung up the handset after putting someone on hold when you pick it up on your end you will hear that beeping noise that you are talking about. Have them pick back up the line while you are on it and replace the handset again on thier phone to disconnect completely.
I hope this helps (trial and error)
Oct 04, 2007 | GE 29488GE2 Corded Phone
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
HP 1040 Plain Paper Inkjet Fax Logo
Ben Johnson
