Question about Belkin Computers & Internet
How can i connect my router dsl port to ethernet modem from virgin braodband
    Sergeant:
    Champion:
  • 258 Answers
You might need an ethernet cable to connect the internet through your pc
Posted on Sep 19, 2008
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
How do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
Can i use a wireless cable modem gateway (netgear) to make my current dsl modem connection wireless.
If your DSL-modem has one Ethernet port, then use an Ethernet cable to connect from that port to the WAN port on your NetGear router. Then, the router will provide both "wired" and "wireless" connections to your computers & devices.
Feb 13, 2011 | Computers & Internet
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    How to set up wbr-3406 tx router with dsl modem
    Take an Ethernet cable, and connect the Ethernet port on the DSL modem to the WAN port on the router.
    Take another Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer.
    Now, you should be able to web-surf.
    Access the web-server inside the router, and run the "Wireless Network Setup Wizard", to configure your wireless networking.
    Jun 24, 2010 | CP International WBR-3406TX Wireless...
    Connecting to virgin cable modem
    Hey, connect a network (straight through cable) from the blue socket on the modem to the WAN socket on your router (This socket will be split away from the other 4 on the router), then turn on your router 1st then modem.
    Good Luck.
    Nov 13, 2009 | Computers & Internet
    I don't know how to connect my router. please help
    If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
    Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
    11g wireless adsl modem router tew-435brm
    virgin media is dsl not adsl which is the router you had
    Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
    How to install a linksys router to my desk top for my wireless laptop
    1. plug in the router
    2. connect the router to your DSL or Cable Modem using the supplied ethernet cable
    3. connect the router to your computers ehternet port with a second piece of ethernet cable
    you can use catagory 5 ethernet cable , or catagory 6
    Most linksys routers have 4 to 5 ethernet ports to connect computers to.
    One of the ports will be marked as the one to connect to your DSL or Cable Modem
    Usually when looking at the back of the router the WAN port will be located to the far left.
    Thank you for choosing FixYa!
    Az.
    Sep 19, 2008 | Computers & Internet
    Wireless connection
    The first step to try is to reboot both the router and the cable/DSL modem. Turn off your computer, and unplug the router and the modem from the mains. Wait one full minute, then plug the modem back in. Wait until the lights stop blinking (until it indicates a steady connection). Once that is complete, plug the router back in, and wait until it also stops blinking. Once the router and modem are both back on, then turn your computer back on and check to see if you have a connection. If that doesn't work, then take the router out of the picture -- plug a computer directly into the ethernet port on the modem. You should definitely have an Internet connection at that point. If it works, the problem is in the router. If it doesn't, you'll need to call Virgin Media's help desk for assistance.
    Sep 29, 2007 | Belkin (F5D9230-4) Wireless Router...
    Computers & Internet Logo
    29 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
