Question about Philips PhotoFrame -10 Digital Picture Frame (Milk White) 10FF2CMI
How to display folder contents
How do I get the photo frame to automatically show one folder after another, so that when all images from one folder have been shown, it goes to the next folder and begin there?
You can not
Posted on Aug 01, 2009
How do i move photo's from a external card to a internal memory on a digital photo frame
If you have an external card reader, attach it to your computer by using a USB cable. Your computer should instantly recognize the card.
91514.image3.jpg enlarge.gif Enlarge
Insert a memory card into the card reader. Again, your computer will notice the card reader and make the files (photos) available. 91516.image5.jpg enlarge.gif Enlarge
Open your computer's main system folder, then open the card reader's drive. This figure shows a Windows computer system folder, including a card reader. 4
Open the folder into which you want to copy the image files. You can also simply drag the files to your computer's desktop. 5
Drag and drop the image files in the reader's folder to your computer's hard drive. You can place the files either in the folder you opened or on the desktop.
Dec 26, 2014 | PANDIGITAL 7" Digital Photo Frame With...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How do you download pictures from phone to digital frame
Most digital frames require a memory card to display photos. The first step is to download your photos from your phone to your computer. Then you need to put the memory card you get for your photo frame into the computer if it has a built in card reader or into an external usb card reader. Next open the file that has the photos you want, and open my computer and select the memory card folder. Select the images you want and press control and c to copy them, click on the memory card folder and press control and v to paste them. Then remove the card and put it in the photo frame.
Jul 30, 2011 | Parrot 7-Inch Digital Photo Frame (Red)...
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
Dec 30, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
I have a Halina Digital Photo Frame DPF070B with no instructions. The screen will display only one picture, I have to manually advance to the next photo vs. a slide show functioning automatically. I made...
Go into the folder where the pictures on your memory stick are stored. There should be thumbnails of all of them and you can select anyone with the red border. Select anyone so it shows up in the picture frame. Now press Enter. Five buttons should show up. Press the middle one to start the slide show. Press Esc to stop the slide show. You can also access the tools settings from here to adjust the interval time. Hope this helps.
Aug 15, 2009 | Cameras
New xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
Jun 16, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
it only will show jpeg images no other formats show.
Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
Nov 30, 2008 | Computers & Internet
Display all photos
Hi, thanks, for your request. You need to be more specifically, set photos on your photo camera or computer?
If it is in the camera, go to the menu section and select the display options brouse thru the options until you see that it shows all pics on the screen.
If it is in your computer, you have to create a new folder cut and paste pics to it.
Thanks
artgirlnyny
Sep 19, 2008 | Philips PhotoFrame -10 Digital Picture...
Philips PhotoFrame -10 Digital Picture Frame (Milk White) 10FF2CMI Logo
185 people viewed this question
Top Philips Cameras Experts
Are you a Philips Camera Expert? Answer questions, earn points and help others
