Question about Nikon D2Xs (Body Only) Digital Camera
Nikond2x's main menu
I really think this is just a problem I am having I bought this camera and it will not allow me to even get to the main menu it will not allow me to scroll to the left. does anyone know how to do a reset any other way ?
    Problem Solver:
  • 8 Answers
Read the manual
Posted on Jul 28, 2009
My camera show the message "no connection", but even if a conect the usb correctly it still appears, the camera allow me to charge, and download the pictures, and see informaton inside, but...
OK, I had the same problem with my 3000, I took it to the beach and after taking 3 pictures it showed the "NO CONNECTION" screen. I tried all of the "RESET" steps with no solution.
After a week I tried cleaning it and noticed that there was a small blue build up inside the USB port so I used a thin soft cloth and a really thin screwdriver to try and clean the port. I turned the camera on and I heard the shutter move and finally the camera worked fine. Also, I cleaned it while the camera was on and noticed that by moving the screwdriver the "no connection" screen would pop back up.
I realized that the seal must have been faulty and allowed the sea water to seep in just enough for the USB port to "short out" and make the camera think that there's a USB cable plugged in hence the shutter will not move when the NO CONNECTION screen pops up....
Now, I know this is probably not the best method, its the only way to do it with out having to pay for repairs or replacement. The warranty is voided because OLYMPUS can always say we were at fault for not ensuring the case was closed properly.
Jun 28, 2011 | Olympus STYLUS TOUGH6020 Digital Camera
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
Hi there, i just bought a 60D and trying all the functions it has. When im on any creative mode and the lens is set to AF, i cant seem to take a picture or even adjust the AF mode. i even couldnt open the...
I don't think it is something you did wrong. What you can do is go into menu, and clear "All camera settings". This will set it back to default mode. Then try to see what does on af on lense. See if will work on mf mode as well.
Dec 27, 2010 | Cannon Cameras
I have a canon powershot SD400 elph. Camera menu
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 12, 2009 | Canon Cameras
Camera Wont turn on
It really could be the batteries. You may want to buy a very good pair of high power Duracell or Energisers first just to make sure that the problem is not with the camera.
I bought my mother this HDC-1061E camera and it was fine for not very long until it seemed the batteries that came in the camera box ran out. A short time. And I offerred a new pair of batteries I found lying around, they were cheap batteries I would use for something not requiring much power. And they brought the camera on but it went off within a second or two each time.
Though then I recalled an 8.2 mexapixel camera I bought for myself last year made by Kodak, and I found that some cheap batteries would not even turn that camera on. And expensive duracells didn't actually last long at all.
What's the solution? Buy a couple of 4 packs of NiMh (2700, no less) batteries (UniRoss is a good buy for this, around £9.99 a 4 pack in Amazon), and a recharger separately. If you're thinking about the environment you should think about a solar recharger though that will recharge a good amount slower than recharging from the mains (there are some more expensive units, if you look around, that offer solar and mains recharging).
I suggest two 4 packs so you have the batteries you are using, another set to exchange for a long day out (maybe not so long in fact, these cameras eat batteries so quickly), a further pair of emergency batteries, and then a pair kept always at hand at home if you need to load fresh batteries at any time. Recharge as soon as used.
A cheapish mains recharger won't cost more or much more than £13 to £20 and may esaily be a few pounds less. Solar rechargers are available in this bracket too, usually a little more expensive than mains ones. If you buy the battery I have specified this should work fine.
Jul 02, 2009 | Hitachi M2L Digital Camera
I think I have messed up!!
I can definitely Fixya!
Ill walk you through it.
Get on the main menu screen.
Settings if the 5th one down on the main menu
Language is the 13th one down on that Settings page.
See if you can do it that way if not. at the bottom of the settings page regardless of language it should say "Reset all settings" and that should let you choose a language.
If none of these work and you dont mind restarting all over with your ipod you can Visit apples page about how to reset an ipod. ( http://support.apple.com/kb/HT1339?viewlocale=en_US ) After reset it will allow you to select your desired language. which im assuming will be English.
Jan 12, 2009 | Apple iPod MA446LL/A MP3 Player
Memory is full
You can only use a 2GB SD card. It is in the manual. I'm not sure on dvd.
Oct 24, 2008 | Mitsuba DV9002 Flash Media Camcorder
After reseting the dsc w50, becouse of e .91.01., flash is not working
hi worked for me , remove battery take apart, discarge the capistor i think 320 volt DO NOT SHORT THE CAP !!!when dead voltage on cap ,turn on reset all camera and try good luck
Aug 31, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
View finder
I had the same problem, it is the switch inside that is broken which allows you to switch back and forth between viewing pictures and taking them. There isn't really a fix besides getting the switch replaced and I am having a very hard time trying to find parts for mine. Good luck.
Oct 28, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Memory Quit working
Hi there, please check with the Nikon Dealer the 4G card compatibility issue, maybe the card is too big for your camera. Best regards, Arpi
Jun 17, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon D2Xs (Body Only) Digital Camera Logo
69 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
