Question about Cooper Industries Cooper Wiring CS220V AC Quiet Switch, Double Pole, Ivory
3 way light switch
I have had an outside light fitted just outside front door, want to put a 3 way switch in coz there are 2 other lights there already, how do i wire it up?
  • 32 Answers
YOU ARE GOING TO NEED TWO TWO WAY SWITCHES AND ONE INTERMEDIATE SWITCH. SEND ME AN EMAIL AND I WILL SEND YOU A CIRCUIT DIAGRAM. THABIET@TJBTRANSPORT.CO.ZA.
YOUR OTHER OPTION IS TO GET AN ELECTRICIAN THAT KNOWS HIS JOB.
Posted on Sep 07, 2009
  • 550 Answers
With an electrician
seriously,
there are too many ways to wire a three way switch circuit, to guess at, and they are not all compatible if the ends are wired differently, a sparky has the tester to be able to tie the third switch in.
Posted on Sep 26, 2008
I have a 2004 chev Express box van and my tail lights wont work every blinker works just not the lights both sides replaced bulbs still nothing
Fuse Usage 1 Climate Control 2 (HVAC) 2 Compass 3 Ignition Switch, Theft Deterrent System Module (PK3) 4 Upfitter Courtesy Lamps 5 Climate Control 1 (HVAC) 6 Empty 7 Instrument Panel Cluster 8 Audio System, Chime 9 Auxiliary Park Lamp 10 Auxiliary Trailer Back-up Lamps 11 Remote Function Actuator, Tire Pressure Monitor (TPM) 12 Climate Control (HVAC) Controls 13 Trailer Park Lamps 14 Front Park Lamps 15 Taillamps, Back-up Lamps 16 Empty 17 Steering Wheel Sensor 18 Outside Rearview Mirror Switch 19 Empty 20 Empty 21 Rear Defogger 22 Outside Rearview Mirror Heater 23 Empty 24 Empty 25 Cargo Door Unlock 26 Rear Door Lock 27 Front Door Lock 28 Rear Passenger Door Unlock 29 Upfitter Park Lamps 30 Front Passenger Door Unlock 31 Driver Door Unlock 32 Airbag System, Automatic Occupant Sensing (AOS) System 33 Right Rear Park Lamp 34 Left Rear Park Lamp 35 Upfitter Auxiliary 2 (J-Case) 36 Upfitter Auxiliary 1 (J-Case) 37 Rear Blower (J-Case) 38 Empty (J-Case) 39 Run (High Current Micro) 40 Park Lamps (High Current Micro) 41 Empty (Mini Micro) 42 Upfitter Auxiliary 2 (High Current ISO Relay) 43 Retained Accessory Power (RAP) (High Current Micro) 44 Rear Defogger (High Current Micro) chevrolet-express-fuse-box-floor-console-fuse-block-247x300-3m55w415sdhfmumhyuzqkab2-3-0.jpg
Jul 27, 2017 | Cars & Trucks
How can I lock a renault megane 56 plate without the key card as it is not working
Locking/Unlocking the doors from the outside
This is done using the RENAULT Card; see the "RENAULT Card" information in Section 1.
In certain cases, the RENAULT card may not work:
- if the RENAULT card battery is weak, flat, etc.
- if equipment operating on the same frequency as the card (mobile phones, etc.) is used;
- vehicle located in a high electromagnetic radiation zone.
It is then possible:
- to use the key integrated into the card to unlock the front left-hand door;
- to lock each of the doors manually;
- to use the interior door locking/unlocking control (refer to the following pages).
Using the key integrated in the RENAULT card
Insert key 1 into the lock in the driver's door and lock or unlock. Locking the doors manually
Turn screw 2 with the door open (using the end of the key) and close the door.
This means that the doors are then locked from the outside.
The doors may then only be opened from the inside or by using the key in the front left-hand door. Interior locking/unlocking door control
Switch 3 controls the doors, boot and, depending on the vehicle, the fuel filler flap simultaneously.
If a door or the tailgate is open or not closed properly, the doors and tailgate lock/unlock quickly.
If you need to transport objects with the boot open, the other opening elements can still be locked: with the engine stopped, press switch 3 for more than five seconds to lock the other opening elements.
Locking the doors without the RENAULT card
For example, in the event of a discharged battery or the RENAULT card temporarily not working, etc.
With the engine switched off and an opening element (door or boot) open, press and hold switch 3 for more than five seconds.
When the door is closed, all the doors and the tailgate will be locked.
Unlocking the vehicle from the outside is only possible with the RENAULT card in the vehicle's access zone or using the key integrated in the RENAULT card.
Door and tailgate status indicator
With the ignition on, the warning light integrated in switch 3 informs you of the locking status of the opening elements:
- indicator light on, the doors and tailgate are locked,
- indicator light off, the doors and tailgate are unlocked.
When you lock the doors, the indicator light remains lit and then goes out.
Dec 12, 2015 | Renault Megane Cars & Trucks
2007 POLO GTI 1.8T... my interior lights don't switch off? light switch turned off, engine switched off, key pulled out of ignition, door locked but the interior illumination stays on
there must be a switch on the actual light fitting to set it to 1 always on , 2 always off , 3 on when door opens , check the switch position
Nov 04, 2014 | 2007 Volkswagen GTI
Trouble wiring timer
If these lights are on 2 way switch you are going to have to figure out which wire runs to your outside lights. If you aren't familiar with 2 way switches here's a link to a site that will help:
http://2wayswitch.com/2-way-switch-wiring-diagram/
If you look at the diagrams on this site, you will see that ONE of the switches has a wire that runs to the light. I don't know which switch this is in your case.
You also need to decide if you want to be able to override the timer with the switches. Also, please confirm that the switches are 2 way (meaning that you can always turn on the lights from either switch). Sorry I couldn't explain more but I need to know whether the timer has complete control over the lights or if you want the switches to override the timer.
It might be a little trickier than you might think. Good luck and be careful.
Mar 13, 2010 | Woods Industries 59377 Indoor Digital...
2002 dodge dakota all lights work and no brake light put new bulb in still no brake lights
check the fuse, it is usually located under the dashboard or between the door and the dashboard.
Oct 14, 2009 | 2002 Dodge Dakota Club Cab
2005 Equinox interiot lights don't work with doors or dash switch
ck interior light fuse (10 amp) make sure the dome lamp is not in the OFF position. with the mirror, the outside temp sensor could be bad or disconnected. the sensor is near the front grille, in front of the radiator. a little 2 wire sensor. if it has been wrecked, maybe it did not get put back on.
Sep 18, 2009 | 2005 Chevrolet Equinox
Dear Sirs, I need help please. I have 3.3L 1996 Dodge Grand Caravan. She becomes old and the troubles started to come up. Here I line up the trobles maybe you can help me: 1. Service Engine Soon light is...
1. service engine 2. replace airbag 3. actuator or switch is going out. If you hear the door trying to unlock it is the actuator if you don't it is the switch.
Jul 07, 2009 | Pro-Fit Pro.Fit Dg 71 01 Dodge Dakota...
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
Light sensor
The light sensor is in the dash board top about 2/3rds of the way over toward the passenger side. You will see 3 or 4 small slits, and that is where it picks up the light, or absense of light. Is the twilight control switch, located under the main light switch, in the position to turn the lights on automatically? It is a slide type switch, and must be slid over to the right for the automatic control to work.
Aug 24, 2008 | 1990 Buick Riviera
Cooper Industries Cooper Wiring CS220V AC Quiet Switch, Double Pole, Ivory Logo
640 people viewed this question
Top Cooper Industries Electrical Supplies Experts
john h
Gene Haynes
obsteiner
Are you a Cooper Industries Electrical Supply Expert? Answer questions, earn points and help others
