Question about Samsung VP-D361 Mini DV Digital Camcorder
Data transfer please could you explain in laymans terms how i transfer the the tape data onto my p.c. & what leads i need to purchase thanks brian nash
    Master:
  • 763 Answers
Sir i dont know laymans terms but in english i can explain to you on how to transfer your videos to your computer.
Posted on Sep 19, 2008
I have a minolta CS pro and got a C0210 code. Please give answer in layman's terms please.
Hello this is going to be an issue with corona wires it could be the charge corna unit or the transfer seperation unit check the corna wires and springs that hold the corona wires in place if corona wire is bad replace also check for arching on the ends of the corona asseblys you can normally smell the arching or you can just replace the charge unit for the drum unit and the transfer seperation unit as well
Feb 03, 2011 | Minolta EP4000/5000 CS/PRO Copier
The check engine light on my Chevy Silverado cam eon and the code was P0449. My manuel says it is the Evaporative emission vent valve solenoid malfunction. Laymans terms please?
That is laymans terms. That is why it is in your manual. You ,need to get up to speed ,on todays somewhat high tech vehicles.
Now you need to go to a shop that does EVAP testing, with a smoke machine,if necessary,or at least put a scanner on it ,and replace the vent valve solenoid,if bad.(again laymans part teminology,
May 12, 2010 | 2005 Chevrolet Silverado 1500 2WD
How do I retrieve info. from a 3M TR-1 minicartridge?
Firstly. sorry to hear of your loss.
I believe you will need a Travan tape reader to access the data on the tapes.
From what i have seen, there are a few available on E**y.
Sorry i can not be of more assistance.
Best Wishes,
Karlos
Jun 28, 2009 | 3M Imation Travan Storage Media
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
Nov 13, 2008 | Canon MV650i Mini DV Digital Camcorder
TRANSFERRING VIDEO FOOTAGE TO COMPUTER
you can access via USB only SD card on your camcoder.
The only way to transfer from the tape is via Firewire (IEE 1394) . You should have this port on your PC or laptop, if not you can buy external firewire card .
regards,
Konstantin
Aug 06, 2008 | Canon MV530i Mini DV Digital Camcorder
Need to copy HVS to DVD. I have a Go Video DVR4200 model
Recording DVDs is a whole 'nother ball game. The data has to be all prepped and then recorded in one shot. Can't just start and stop like a tape machine. Half the reason for pushing DVDs on the market is prevent you from easily recording them. Takes either a special recorder ($$$) or a computer with a writable DVD drive.
Jan 17, 2008 | Televison & Video
Samsung VP-D361 Mini DV Digital Camcorder Logo
164 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
