Question about Infinity BASSLINK Car Subwoofer
INFINITY BASSLINK X BLOWS FUSES
I am a technician but have no schematic OR recent experience. My Basslink X blew the 20 amp fuse. It's own fuse. I found that one of the switching xistors ahead of the torrid transformer was dead shorted. I replaced both of them with exact replacements. I powered up the unit but limited the current to under 10 amps. When the trigger lead is on it would have blown the fuse. With the lead off it does not blow the fuse after the transistors were replaced. Is there anything that is a "frequent problem" with these units? Note: the bridge rectifiers just after the torrid are fine.
What probably happened was both of the final audio output transistors shorted. This caused a higher than normal drain on the switching transistors on the primary side of the torrid power transformer causing one to short and then blowing the fuse. I replaced both switching transistors and ramped up the current to about 5 amps. I could see the power supply was not working but there was still a short. I traced the short to both audio output transistors. Replaced them and unit is like new. After I found a service manual on this item it was a breeze to find the problem.
Posted on Sep 21, 2008
  • thiago migliozi Mar 28, 2013
    sorry for restoring this thread but i'm currently running through the same issue and i just saw that transistors D105 and D106 were shorted. After taking them out, i see that they are fine but the circuit in which they are is shorted. I cant trace which transistor is causing the shortage, do you guys have any idea?
My cars battery died, and when i turned the car on finally the head unit and my infinity bass link didnt turn on
Check the fuse in your car's fuse panel. If it is burnt then change. If it is still good, check the fuse on the head unit and amp.
Sep 03, 2012 | Infinity BASSLINK Car Subwoofer
Basslink Fuse Blown
if it has a short some where in the lines it will do that
Feb 25, 2010 | Infinity BASSLINK Car Subwoofer
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink Stoped working after a month ** sound ** red LED
check all your power fuses and insure you havec power where it is supose to be. maybe you have blown a fuse.
Mar 09, 2008 | Infinity BASSLINK Car Subwoofer
No Sound from Basslink
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
Feb 02, 2008 | Infinity BASSLINK Car Subwoofer
Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
Jan 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink
make sure ur ground cabke is as large if not larger then ur poweer cable.
Oct 11, 2007 | Infinity BASSLINK Car Subwoofer
Amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Dec 21, 2006 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
680 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
