Question about Akai LCT3701AD 37 in. LCD Television
Akai LCT3701AD refuses to leave STANDBY mode.
TV won't Power up! (Power Indicator Remains Red, will not switch to Green).
  • 35 Answers
Hi
ebay selling cheaper price power supply please check out:
AKAI LCT3701AD POWER SUPPLY BOARD MLT386X
Posted on Jan 17, 2009
  • 2,323 Answers
The power supply on your LCD is defective. It does not provide the power needed to all the circuitry due to defective capacitors or other components.
You will need to replace the power supply or get it repair because these service parts are not longer being manufactured.
Good Luck.
Posted on Sep 19, 2008
I have a AKAI LCT3701AD 37 inch TV don't have the original remote control but bought a universal remote control but is not working Why?
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
Jan 23, 2017 | Akai Televison & Video
MY AKAI TV MODEL#LCT3701AD DOSNT WORK MENUELY AND REMOTE THE RED LIGHT IS COMMING BUT DOSNT TURN GREEN
Hi, when you turn on your tv does the red led flash in a pattern... does it flash a certain number of times quickly and then pause and
then repeat
If you can give information on this it will gretly assit us in diagnosing. Can you please check then add the details and repost the query.
If there is no pattern that may also help
Jul 03, 2015 | Akai LCT3701AD 37 in. LCD Television
Akai lct3701ad tv will not come on
I would suspect a power supply problem in the set---voltages there would confirm or remove it as the possible answer.
If you find puffed up caps on that board you have found your problem--it is the place to begin.
Aug 29, 2012 | Akai LCT3701AD 37 in. LCD Television
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Remote code wanted
Hello
Three digit universal remote code for Akai TV are: 002/ 0030.
Four digit universal remote codes for Akai TV are: 0105 0002 0077 0254
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jul 01, 2011 | Akai LCT3701AD 37 in. LCD Television
Need Power Supply for Akai LCT3701AD
This post might be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 07, 2008 | Akai LCT3701AD 37 in. LCD Television
TV ON STANDBY MODE
The blinking light on the front indicates a shorted part in the power supply. The power board will need to be replace or repair to restore the LCD functionality.
Let me know if you required further assistance.
Oct 06, 2008 | Akai LCT3701AD 37 in. LCD Television
AKAI LCT3285TA seems to be stuck in "Standby"
Greetings,
We own a small TV repair shop in Ohio and have ran into similar problems with this TV.
To fix this problem we replaced 3 caps near and in the powersuppy of the TV.
This TV is very sensitive to electrical problems ( more then most if that's possible) so check the caps near the PSU.
Over all this TV is a fairly decent product.
Aug 07, 2007 | Akai LCT3285TA 32 in. LCD Television
Akai LCT3701AD 37 in. LCD Television Logo
362 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
