Do you mainly use it on a Mac? Do you want to use it for both Mac and PC? If it's the latter, you can format your USB drive on your mac using disk utility and formatting it as ExFAT. This way it will be recognized on both Mac and PC and you can save files onto it as well.
Where if you formatted it to Mac only you will only be able to write to it on Macs and not PCs.
Hope that makes sense
SOURCE: USB flash drive wipe out
I went to the Sandisk website and they actually have a bunch of how-to videos on there that will help you out with your problem: http://www.sandisk.com/Retail/Default.aspx?CatID=1459 As for getting your information back, you would need special recovery software in order to do that. Here is a link that might be able to help you with that: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
SOURCE: Kingston Data Traveler 2.0 64 GB USB - file system
2gb kingston pen drive showing capicity only 4 mb so pls provide the solution
SOURCE: Seagate external 2.0 USB 60GB harddrive
Well, in your case your external may corrupt. The solution is format the drive and then try some so-called data recovery software. After finishing the format option. Do it as follows.
Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
