Question about Belling Microwave Ovens
Microwave not cooking food
Micro turns on light on and turn table goes around but food does not cook.
  • Belling Master
  • 9,086 Answers
Chances are you have a bad high voltage parts, such as the high voltage rectifier diode, a bad magnetron, a loose connection at the magnetron, or less likely, a bad high voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
To order parts or find your nearest authorized servicer, please use the contact information in your owner's manual.
Posted on Sep 27, 2008
I have the Dacor DCM24 microwave and if the table does not spin will the microwave still cook food. I think my turn motor is bad, but wanted to know if I could cook food without it?
Yes! it will continue to cook food, the only difference you may end up with cold spots in the food, rotate plate once or twice to reduce this.
May 30, 2012 | Dacor DCM24 Convection/Microwave Oven
The motor will not work. The interior light comes on, but the turntable does not go around. The cook time counts down, but no cooking occurs.
the turn table motor could have failed, but the counting down will be the monitor switch or a micro switch located behind control panel
Feb 24, 2011 | Amana ACO1860 Microwave Oven
Turntable in microwave does not turn. is it dangerous to keep using it?
hi. ther is no problem using your micro with the table not turning. as long as it still heats. the turn table is usually the first to go. i have had a couple like that and used them for a long time with no problems. you should be fine. hope this helps ease your mind. have a good day!
Jan 15, 2011 | Microwave Ovens
Does not cook food. the microwave oven appears to be working but it doesn't cook the food. Turn-table works, timer works, the light in the oven is on but my food does not cook, defrost or warmed up.
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
Jan 26, 2010 | Sunbeam SBM1000 Microwave Oven
Little plastic ring with wheels broke in several places
the purpose of the turntable is to more evenly cook the food. it shouldnt effect the mics ability to cook, just might take a little longer to thoroughly cook food
Apr 21, 2009 | Emerson MW8625W Microwave Oven
When we first turn on the microwave there is like a mini-explosion and a fiery spark, but after that the microwave goes through its cycle and cooks the food. But we are afraid to try it again.
pls do not use any aluminum or metal material INSIDE the microwave, this can cause the problem
I assumed, but pls consider the ff info...
Be sure to use nonmetal utensils in the microwave.
For microwave cooking, cut meats and vegetables in uniform sizes to make sure that they cook evenly.
Paper plates, cups, and napkins can be used in the microwave. But don't use foil-lined paper products, paper towels that include nylon or synthetic fibers, or newspaper.
When using plastic roasting or cooking bags in the microwave, discard the wire twist tie and use a plastic fastener or a piece of string instead.
To ensure that food cooks fully and evenly in the microwave oven, stir food and turn dishes periodically while they're cooking.
Jul 25, 2008 | Microwave Ovens
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
MMV5000 cavity light off when is pressed...
The wiring diagram indicates that there is a cavity lamp switch on this model. It should be under the control panel or somewhere else on the underside of the oven. The noise you describe could indicate trouble with the fan or the magnetron, etc. If you could describe it in more detail we may be able to offer more advice.
Mar 04, 2007 | Maytag MMV5000 Microwave Oven
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Microwave Ovens Logo
203 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
