Question about Nokia 3230 Cellular Phone
Nokia 3230 hi guy my imei is 359362007181622 i want to apply my orig phone setting but i forget the code pleaseeeeeee help me
  • shankar guru Sep 26, 2008
    sir my imei is 359362007181622 i forget my orig phone setting code
You can dial *#7370# then your mobiles security code
Posted on Oct 08, 2008
My cell is Nokia 3230 i have forget my security password what i have to do. i have formated but no use
Download this Software : CLICK ME
* extract the file and open it.
* enter your mobile's 15 digit IMEI nos. located at the back of the mobile or just simply typ *#06# (the imei/serial will appear)
* press calculate
* enter the given code to your mobile (security code)
*DONE
Jun 08, 2011 | Nokia 3230 Cellular Phone
Hi how can to unlock my memory card when i forget my password for nokia 3230 mobile please help me
Try standard code like 1234, 12345 or this code ( .adgj ). If still cannot unlock please put your memory on nokia phone model 9210 , 9300 , 9300i or 9500. It will remove the password
Dec 27, 2010 | Nokia 3230 Cellular Phone
I forget my orig. phon setting...so i can't restore..ples help
Tools Required :
• Nemesis Service suite (NSS)
• Nokia PC Suite
• Data cable
Steps :
1. Connect your phone in PC Suite mode
2. Open Nemesis Service suite (NSS)
3. Then click on scan for new devices button (top right hand side)
4. Click on phone info button.
5. Now Click on Scan.
6. Select Permanent Memory.
7. Click on Read.
8. It will read the permanent memory file and save it on the disk at following path.
C:\Program Files\NSS\Backup\pm\<IMEI>.pm
9. Open the .pm file using Notepad.
10. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there.
11. Like 5=31313131310000000000
12. Remove all “3” digit and it will be 31313131310000000000
13. 11111 is your security code.
14. Done!!
Once you find the security code you can restore the settings by "Restore factory settings" option. Rate me if it is helpfull!!
Aug 19, 2009 | Nokia 7610
I forget code which i inter before.
flash your phone using a computer. the new security code will be*1234* then you can change the code as you like
Aug 17, 2009 | Nokia 3230
Restores setting for nokia 3230 i forgot my code help me
The default master code for nokia is 12345. If you have changed this default one, then go to the following website, enter your IMEI number, and get the unlock code.
www.lur.nu/nokia_mastercode/security_code.php
Hope my info helps you,
Thanx for using fixya,
Cheers.
Oct 22, 2008 | Nokia 3230 Cellular Phone
Security code...
Here is your unlock code - 5757763176
Please do reply me when the issue is resolved........and also don't forget to rate the solution...
Sep 30, 2008 | Nokia 3230
Forget my nokia orig phone setting code
Hi there
Thanks for posting your problem on fixya
Please read this carefully it will help you how to use your this master code
Master code : 7571575713
1. Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI
number. Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your
phone is the Nokia 3390 phone, select the model 3310, they are the same phone.
You will get a series of codes that looks something like: #pw+555 979 507 5+1#. You will enter each of these codes until you find the one
that works for you, it’s possible the first one won’t work.
2. Remove the SIM card from your Nokia phone. This is typically done by removing the back cover of the phone and removing the battery and
sliding the card out. Put the battery back in and power the phone on.
3. You should see a message “Insert SIM Card”. Begin entering your generated code. Enter all of the characters you see in your code,
including the # symbols. To get a ’p’ press * 3 times, to get a ’+’ press the * key 2 times, to get a ’w’ press the * key 4 times. Disregard any
spaces in the code.
4. Once you have finished entering a code that works you should see a message that says “SIM is not restricted” or “Restriction off” message
depending on your model. If not, try entering another code. Be careful, entering a wrong code 5 times will mean that you will only be able to
unlock the phone with a data cable.
Pls rate this solution according to its use in you. it will be much appreciated........
Thanks
Robert
Sep 28, 2008 | Nokia 3230 Cellular Phone
Security Code for Nokia 3230
if your IMEI contains any slash symbol like "/"this after some digits means you include that also & send me i will see to it ...
Jul 09, 2008 | Nokia 3230 Cellular Phone
here is the code to reset for your imei :
*#5620131056#
if you have given the imei number correctly then it works otherwise no use .........
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution
Nokia 3230 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
