Question about Samsung HP-R5072 50 in. Plasma HDTV
Samsung ps42a457 42" plasma tv
I am going to buy this model. can you tell me if this is a good product or do they have lots of problems.no shops will give screen burn in their guarantees and this worries me a bit. thank you from kathleen sweeney,glasgow
  • 4,234 Answers
Screen burn in will only occur if you keep the same image for an extended period of time. This can be cleared if you send a pure white image to the set until the "burn" is cleared. In normal home usage, burnin is not a problem unless the set is used for gaming all day. No manufacturer will replace a panel due to burnin. Burnin should not be a consideration when selecting a set.
Dan
Posted on Sep 19, 2008
Correct inverter board for Samsung plasma TV
http://www.lcd-plasma-parts.co.uk/bn41-01180a-bn94-02845a-samsung-ps50b450b1wxxu-main-board
read the page above to get pointed in the right direction as it helps to explain what is required to order the correct board
Jan 02, 2017 | Samsung Televison & Video
Model pn50b450b1dxza plasma. Why won't it stay on?
the problem covers many different things and the inside of a plasma TV has high voltage; take it to a repair shop or buy a new TV.
Oct 03, 2015 | Samsung Televison & Video
I have a 50 inch samsung plasma. It is getting lines all the way across the screen. I'm up to 47 lines is there anything I can do to fix it?
Several things can cause problem with plasma TV's. You may be getting electrical noise from an appliance or lighting such as halogen or florescent, dimmers, bad electrical connections and outlets. Also, bad cables can cause problems too; have you tried switching those out? Appliances like vacuums, fans, regrigerators, anything with a motor can cause lines and noise on TV's. Have you tried connecting the TV to a noise suppressing, surge protection power strip? Do the lines come and go, or are they consistently in the same place all of the time? When did you buy the TV and is it still under warranty or an extended warranty? Do you have problems with any other TV's in the house? Look at each of these solutions, try them one by one to narrow down the potential source of the problem. If you've tried everything I've mentioned, it may be a bad TV. It does happen, but not often. And as a former Samsung dealer/installer, I know Samsung products have really good track record. In fact, every TV and smart phone phone in my home is Samsung. Hope this helps.
Feb 07, 2015 | PN50C675 Samsung Factory Refurbished...
I was going to get a plasma TV specifically the Samsung PN50C6500 and i was wondering if the whole thermal expansion controversy problem was over and samsung had become more reliable and this problem had...
No,don't buy plasma tvs any tvs make or tvs brand.Don't buy any kind of tvs using plasma gas as for plasma screen panel as a power sourced if u play major hours of gaming on the plasma tvs,u will still have thermal expansion problems but less.Plasma tvs still have major problems,with screen BURN IN problems though.
Aug 22, 2011 | Samsung PN50C6500 50 in HDTV Plasma TV
Where can i find an authorized samsung plasma tv repair shop in the bethel park pa area
You can find the nearest center to you by going to;
http://www.samsung.com/us/support/service/location
You will need to enter;
TVs for Product Types
Then
Plasma TV for Product Subtype
Then the model number of your set
and your Zip Code
Click on GO icon
Apr 03, 2011 | Samsung HP-S5053 Television
I have a Samsung 42 " Plasma Model no: PS42Q96HD.
Hi, this could be a problem with the power supply in the tv, it is common especially on some Samsungs and specific repair kits are available quite cheaply if you have good soldering skills.
Usually this is caused by capacitors that have dried up and split, you can normally tell as the capacitors are bulging on the pcb, you can get them in a kit as I said eBay sometimes do them or you can buy them indivually from a good electronics components supplier, make sure you get the correct values for each!! marked on the side of the capacitors in xx/x V, xxx/x uF and 105oC. (the x's represent numbers)
The picture below shows the type of theing that happens, the brown ones are bulging/split on the top whereas the black one is fine.
High Voltages can exist in these sets, never attempt anything while plugged in and
if in doubt do not attempt it yourself and seek the advice of a qualified TV Technician.
Feb 10, 2011 | Samsung HP-R4262 42 in. Plasma Television
Have a plasma samsung hpt5054 i have sound no picture is it worth fixing thanks
On a plasma that usually means a problem in the power sections. You should be able to get an estimate from a repair shop or Samsung repair depot. On that size of tv it should be cheaper to repair than replace unless it is several years old. Usually on a smaller tv just out of warrenty the cost to repair is worth more than just going out and buying a new tv.
As long as you know your replacement cost and get an estimate you will come out on top.
Jun 14, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Any problem with lg 60pg60. good tv??
I as a technician that repairs LG,Sony,Hitachi,Mitsubishi,Samsung ,etc..Have found that LG is the one brand that I have nothing bad to say about.I love working on their products and they have the best support for technicians compared to all other brands.You as a customer can benifit from this because of the vast knowledge that technicians will have if you were to have a problem.As I stated I work on all brands in warranty and out and LG parts are cheaper than most.On the other hand you may buy another brand only to findout it was made by LG. Philips,Toshiba,are examples of this some of their units are made by LG,And chances are 50% of the Plasmas on the market contain LG made plasma panels.Good luck hope this helps.
Jan 20, 2009 | LG 60PG60 60 in. Plasma HDTV
Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Onece the plasma heats up it shrinks a little, i think the cause is that you are low on plasma, so when i heats it shrinks and since the plasma cycles, the area low on plasma wil move slowly around the screen, take this to a repairman and more plasma can be added to it.
Jun 19, 2008 | Samsung LN-R268W 26 in. HD-Ready LCD...
Samsung HP-R5072 50 in. Plasma HDTV Logo
136 people viewed this question
Henry  Thomas
Henry Thomas
