Question about Lexmark P4350 All-In-One InkJet Printer
Failure to print
The printer appears at first to be printing, BUT it seems not to be "delivering" the paper, coming up with a signal either that it needs more paper, which it doesn't, or that there is a paper jam, which there isn't. How can I get normal service to resume?
Nu merge
Posted on Sep 29, 2008
Hello! I have a Magicolor 2300W that has been standing unused for some time and it won't print correctly. The printer feeds paper from the tray, it goes through the printer, comes out at the top - but...
1. Check the paper size your printing on and whether the Same is used by printer or not 2. Try shaking the cartridges as they may have got stuck at their places for long time 3. Try legal or a4 or letter size for paper
Jan 01, 2014 | Minolta magicolor 2300W Laser Printer
Ink System Failure. 0xc19a0003 is displayed on my printer.... what will I do?
First try to Reset the printer.
Normally a Ink System Failure message points to a problem in the printhead of the printer.So,Remove, clean, and reinstall the printhead
If it is not working again,then you should contact your manufacturer.
**If you need any technical help on printer then you can reach at here
Mar 08, 2013 | Office Equipment & Supplies
My samsung CLX2160N keeps printing with no ink on the pages and even though I print one page it just keeps spitting paper..also the green drum in the printer appears to be covered in black ink
If the toner is not empty and you notice that the toner assembly is dirty with print dust, then it probably is an issue of transfer corona failure. You will have to replace the entire printing mechanism. But before you go out and cash out over $200 for the new assembly it's best that you take the printer back to the shop where you purchased it. The print assembly warrants over 50.000 printouts, and if you haven't printed out so much it may still be under factory warranty.
If you haven't used the printer too much (never replaced toners, never printed out over 500 pages total) then there's an easy way to verify if the transfer corona is really the problem. Pull out the print assembly and check to see if the waste toner tank is full/overfilled. If it is brimm-full then you're definitely facing a bad transfer corona and you will have to replace the entire mechanism, or find a good repair technician that can fix the existing one.
Another possibility would be if there is some dust on the paper and you can see some of the print powder on the exit tray. If there is print dust on the exit tray that means that the fuser is not working. If the papers that are coming out of the printer are cold then this is deffinitely a fuser failure, and you're still stuck with either repairing the print assembly or cashing out for a new one.
About the problem with the printer spilling out paper all the time, see if you've set the printer to print A4/Letter size printouts or it's set to print infinite paper track (like those old paper formats we see on old 80's movies). Either way, the no print and the paper spitting are not related issues.
Jan 17, 2011 | Samsung CLX-2160N All-In-One Printer
I have a Canon Pixma MX300 all-in-one that is telling me there is a paper jam. Problem is...no paper in the machine! How do I correct this error? Thanks!
Hi, It seems that there is something with the paper sensor of your printer, You can unplug your printer and if possible, open front cover. Now take out ink cartridges and then turn your printer upside down and shake it gently so that if there is any foreign material, it will come out. You can also try wipe all the visible sensors with a soft cloth gently. Close all the lids and try to print again after connecting the printer.
If the printer is working fine as an independent unit, it means the driver installed on your computer is corrupt and need to be re-installed. Alternatively you can connect the printer to other usb port then try printing.
If the paper jam signal still haunts you, there might be some snag with the printer's paper signal section and you need to take it to manufacturer's service center.
Hope you will be get print once again.
Cheers! http://www.techcorrespondent.com/
Apr 01, 2010 | Office Equipment & Supplies
Kodak EasyShare 5300- Won't print
I fumbled around a similar problem today. After printing photos you have to convert the printer to print to paper. If there is a green LED on the printer your are in PHOTO mode. Reach into the 4x6 printer and pull back the slide and the LED will go out. Now you can print on paper.
Mar 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper tray feed problem
the shaft the roller is on is bent or the clutch on the left of the shaft iis broken.
Jan 02, 2009 | Samsung ML 1510 Laser Printer
Canon Pixma MP780 print quality fault
My daugther also has a Pix780 so I just replaced my print head with hers and now the colour prints great. I guess I'll try cleaning mine first and if that doesn't work, I'll purchase a new one when the dealer who services Canon opens on Tuesday. I could also buy one from the Canon website for something like $60. I copied the following from Canon's sites under the FAQs. Sounds like you may need to replace your printhead.
How does a Canon Printhead work?
The printhead delivers very small drops of ink onto the paper. The ink from the cartridge is transported via small tubes. Heating elements heat the tubes, creating a small bubble of ink. The heating element determines the size of the drop to be applied to the paper.
How do I know I may need to replace my printhead?
There are a few symptoms that may indicate printhead failure or a clogged printhead. If the following symptoms continue even after replacing the ink cartridges and trying the troubleshooting steps in your user's manual or those listed below, you may need to replace your printhead:
  • Pages come out blank, or you see poor print quality
  • Pages you print appear to be missing colors
  • Colors on the printed page are quite a bit different from what shows on the screen
  • Horizontal white lines or light-colored lines or light streaks appear throughout the page
Why would the printhead have problems?
After hours of printing, the heating elements may fail after being turned on and off hundreds of thousands of times. The printhead can also become clogged or blocked with paper debris or solidified ink. If your print quality is poor or your printer will not print at all, it may be time to change your printhead.
Aug 29, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Hp laserjet 4250
try this
1.when the printer start print turn off the printer after the paper go on side the printer to make paper jam
2.open the printer and pickup the paper out slowly
3.see the print area on the paper if the black par appears on the paper that mean the drum unit faulty if not the fusser unit faulty
May 14, 2008 | HP LaserJet 4250n Printer
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
I have exactly the same problem with a Canon Pixma MP800, I have cleaned the rollers, changed the ink cartridges and reset the printer. It will print a few pages cleanly then dump black ink on the roller which leaves a heavy black line on the back of the page. It fades away after printing about 10 pages and then a few pages later appears again. The printer is two years old and it looks as if I must buy another. Should I buy another Canon?
Apr 03, 2008 | Office Equipment & Supplies
Print Failure
Try printing a different application or file, try printing a test page form the printer itself does it print an internal test page? then the file has a problem.
Nov 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark P4350 All-In-One InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
