Question about Nikon Speedlight SB-800 TTL Flash
TTL Multi-Flash Sync Cord SC-27
I am using the remote cord, SC-17, from the camera, D200, to an SB-800 flash unit, used as a wireless master flash to 3 more SB-800 remote units. The SC-17 is 1.5m long and I need more distance. Could the SC-27 Sync Cord be used between the SC-17 terminal and the master flash unit without any changes to the system?
  • 62 Answers
YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
AND SHOOT THE FLASHES IN SETTING 4A
NO CORDS NEEDED THEN .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Posted on Nov 29, 2008
I am using a nikon D200 with a sb800. The flash is firing ok on TTL and the camera is set on 'P' however I am getting a dark picture every tme. The built in flash works OK It appears the flash/camera...
This is an excellent flash, very powerful and compact and actually more flash then what was available when the D200 first cam on the market. The two will work nicely together and I think the problem is that the SB-800 can be programmed within itself. This meaning with some cameras you program the camera for the flash output with the SB-800 you can program the flash as well. It has some excellent features like Flash value lock (which I think is set to slightly underexpose from what your question is asking) it also has Flash color information and a built in Flash compensation. Possibly the compensation or value lock are set to underexposure. I'm saying this over the camera setting because you stated that the internal flash appeared to be okay, check your SB-800 settings
Dec 27, 2010 | Nikon Speedlight SB-800 TTL Flash
SB-800 Stuck in REMOTE
http://www.nikonusa.com/fileuploads/pdfs/SB800_sellsheet_060425.pdf
hers the manual on cam look under trouble shooting im still cheaking into it also
Feb 08, 2008 | Nikon Speedlight SB-800 TTL Flash
Sync Nikon SB-800 speedlight with studio lights
keep the Sb 800on the camera hot shoe and elichrome will trigger automati or use a slave unit
Oct 20, 2009 | Nikon Speedlight SB-800 TTL Flash
I want to know how to use the 952AF/Nik with the nikon d200 using multi flash units with the commander mode set to channel 1
The vivtar 952AF flash is not compatible with the D200 in commander mode. Only the Nikon SB600, SB-800, SB-900 will work with that camera wirelessly.
Oct 11, 2009 | Cameras
Flash fires but dosent show up, out if sync out of time with the camera
Wierd, what camera, settings are you using? have you ever tried using the CLS (creative lighting system)? could you have left it on "remote" or "master unit" with it turned off. Then it will send out the preflash but not fire during the exposure.
Sep 26, 2009 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Nikon SC-29 REMOTE CORD
    Hi Kathy,
    Are you ready?
    1. Make sure the Nikon SC-29's Red Panel's Lock Switch is set to the Left. Pointing at Left Black Screw.
    2. Connect the Nikon SC-29's (Red Panel) to your camera's Hotshoe by pushing it as far as it goes.
    3. Turn Lock Switch to the Right (turn CW). This locks down to camera.
    4. Make sure Nikon SC-29 (other ends) AF-ILL is set to OFF.
    5. Make sure your Nikon SB-800's Lock Switch is set to the left side.
    6. Attach your Nikon SB-800 into this Hotshoe.
    7. Switch the Lock Switch on flash to the right.
    8. When you wants to AF from flash, set AF-ILL to "OFF"
    9. For the best results, set AF-ILL to "ON".
    I teaches, do repairs, services and modifications on all photographic equipments.
    I hope they are helpful to you as well as for any Nikon Photographers using the Nikon SC-29 Cable.
    Mine has Autofocus, ITTL, Slave and Wireless Radio Remote Flash.
    Truly,
    atdlee@netzero.com
    Jan 31, 2009 | Cameras
    Sb 800 and sb900 overexposing
    It might be you are not making a good contact on your camera and flash .
    Are you using a cord to get the flash off the camera . If so the cord could be intermittent .
    Jan 26, 2009 | Nikon Speedlight SB-800 TTL Flash
    Nikon SB 800 fires but pictures reamain dark
    make sure your white balance is set to "flash" on both cameras
    Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
    Nikon Speedlight SB-800 TTL Flash Logo
    218 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
