Question about Sharp AR-M205 Copier
A3 Paper the A3 light indicator is not showing
  • 97 Answers
Let me know what is he full details of your problem?
Check the tray they have paper guide to change the size of paper.
Posted on Sep 23, 2008
How do I get a Blow up (say 150%) PDF snapshot view of an image to print from A3 not A4 print tray
Hi Paul,
I would try and insert the PDF as an image to Powerpoint, crop the image to your desired proportions, scale it up to your preference, then print the Powerpoint slide on A3. Alternately, print the slide to PDF, then print.
Good luck
Feb 22, 2015 | Office Equipment & Supplies
How do I select A3 paper from the menu of the richoh 3025 printer itself
You can only select a paper size from the operation panel that the machine has loaded in the paper trays. If your are trying to select A3 and A3 does not show up in the list of available paper sizes then either you do not have that size loaded or the paper size dial in the tray is not set properly. These Ricoh's use a paper size dial in each tray that is designed to tell the machine what paper you have placed in that tray. So it is somewhat common for me to hear from people who have this problem because the paper was changed without changing the dial or the dial has been accidentally moved. I would check the paper size dial in each tray to be sure it is correct.
If I have not answered your question correctly please provide more specific info as to your situation.
Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
Audi A3 showing yellow indicator lamps 1) engine management system flashing 2) Emission control system 3) diiesel particulate filter whats wrong?
Take it to auto zone and have the code's reader hooked up on it and that can tell you the problem
Mar 05, 2010 | 2009 Audi A3
My copy printer can't show a3 paper . how to fix it?
may i know whats the model of your copyprinter?
use an A3 drum.
check if ur using an A3 drum
Jan 25, 2010 | Gestetner Copier
E-Studio 3511 will not print a3
check to make sure on the display panel the paper tray is showing A3 PAPER SIZE>> the paper size indication should match up to what is in the trays if not the machine will be asking for A3. Also try putting in another tray to see if there is a fault with the paper tray .. if it works with other paper sizes it may just be the size hasnt been set properly for that tray.. Hope this helps A
Jan 18, 2010 | Toshiba E-Studio 3511 Color Copier
Unexpected Paper Size error while printing a3 size paper on HP 9300 deskjet printer
Although you have selected the paper size A3 your printer HP Deskjet show unexpected paper size.....
1. clean the carriage area ...........
2. change the carriage sensor....... If not solved
3. you need to replace carriage unit.
Thanks
Oct 26, 2009 | HP Deskjet 9300 C8136A Printer
How do i copy an A3 to A3 paper
put a3 paper in the paper tray and adjust paper size wheel on trays righthand side so it says A3 doh.....................................
Jul 08, 2009 | Ricoh Aficio 2015 Copier
How to reset the settings
Use the bypass tray for A3 or any tray which can also be adjusted to take A3.To adjust the tray, extend the green lever to the place indicated as A3 on the tray then load paper and on the control panel or key panel , press the paper key and hold until it blinks while the rest is off, use the paper select key to adjust to A3 and press print key, then press the paper key again.
Apr 21, 2009 | Sharp AR-5320 Black and White Copier
Printer Problem in HP-1280 Printer
go to printer folder , select properties and go to paper /quality , browse to A3, select, apply, OK
check print preview before sending your document
May 01, 2008 | HP DeskJet 1280 InkJet Printer
Sharp AR-M205 Copier Logo
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
