Question about Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM, 60 PSI, 12 Volt
Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Hello. Everytime I turn on the pump to the sprayer it blows a fuse. It has blown 8 in a row. The fuse is a 10 amp, 32 V fuse. I even tried a 15 amp and it blew it also. Is the pump bad? What do I need to check?
Thanks,
Sandra
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Posted on Jan 08, 2009
Pumps
as soon as your finger is off the trigger
Jul 06, 2014 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Pump sprayer has no suction
We have the exact same sprayer 2.1 GPM for our FIMCO and the engine runs but it will not suction. This happened once before last year and because it was under warranty they replaced it. Now it is happening again but FIMCO will not stand by this part because they don't "Warranty their warrenties.". What a bunch of ****! Stand by your products for pete's sake!!! If anyone has any solutions or ideas it would help us out a lot!
Apr 14, 2012 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Fimco 15 gal Sprayer, 12 volt, No power
cross the wires on the pressure switch, if it runs then, replace that switch is all!
Jul 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is...
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Apr 29, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM, 60 PSI, 12 Volt Logo
1,045 people viewed this question
Top Fimco Garden Experts
lnbn1975
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Are you a Fimco Garden Expert? Answer questions, earn points and help others
