Question about EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Installed new RAM, PC would not boot up.
I have installed a Kinsgton 1GB PC2 - 5300 CL5 240 - Pin DIMM DDR2 667 RAM (KVR667D2N5/1G) to be paired up to another Kingston 1GB RAM (KVR667D2N5/1G - SP) which is exactly the same.
The problem is that the PC would not boot up when I install the ram.
What should I do to let the PC boot and recognize the RAM?
  • astig_tigas5 Feb 12, 2009
    I Install new 1gb dynet ram only 512 display din i turn off my cpu did not boot now & no bib now what happen?
  • 67 Answers
Will the PC boot? It may just be loose. Try it again. The PC may not boot if it does'nt recognize the memory.
Posted on Sep 20, 2008
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
IBM R50e RAM
The RAM modules do not have to be installed in pairs.
  • Max RAM Supported 2.0 GB
  • Technology DDR SDRAM
  • Speed 266.0 MHz / PC2700
  • Form Factor SO DIMM 200-pin
  • Slots Qty 2
May 03, 2012 | Computers & Internet
I have an asus m2n mx (windsor) motherboard and an amd athlon x2 3600+ processor . . . i have a pair of 667mhz 512MB (total 1GB) ram and a pair of 800mhz 1GB (total 2GB). . grand total(3 GB) . . My problem...
The manual for your motherboard states:
For dual-channel memory configuration (2), you may:
• install identical DIMMs in all four sockets OR
• install an identical DIMM pair in DIMM_A1 and DIMM_B1 (yellow
sockets) and another identical DIMM pair in DIMM_A2 and
DIMM_B2 (black sockets)
* Always use identical DDR2 DIMM pairs for dual-channel model. For
optimum compatibility, we recommend that you obtain memory modules
from the same vendor.
Sep 11, 2011 | ASUS M2N-MX Motherboard
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
Has 1Gb Ram installed. Bios not recognizing dimm
was it new ram you bought or was it out of some other machine because it might be a caes of bad ram. try your old ram in the laptop and see if it boots up if so then get your ram chaged.
Mar 14, 2010 | Dell Latitude C840 Notebook
Is it possible to install more ram after installing UBUNTU o/s?
The A280 spec is as follows
RAM
  • Installed Size 128.0 MB / 128.0 MB (max)
  • Technology SDRAM
  • RAM form factor SO DIMM 144-pin
  • The A280 has 1 memory slot and only supports 128Mb
    The A280 IUltra Lte has 2 memory slots and can support 1gb RAM
    Sep 26, 2009 | Sharp Actius A280 PC Notebook
    Installing a third RAM stick causes failure to boot Vista. All RAM sticks work, one at a time or in pairs, in any combination of sockets, but adding a third stick causes blue screen of death and adding a...
    As all clarification requests, you should be more specific so we can help you. Now your problem could most probably be that the third RAM you want to put does not comply for dual channel. If you want to use three DIMMs in a dual-channel configuration, install a matched pair of DIMMs equal in speed and size in DIMM 0 (blue) and DIMM 1 (black) of channel A. Install a DIMM equal in speed and total size of the DIMMs installed in channel A in either DIMM 0 or DIMM 1 of channel B. Your best bet is to have all your RAM in identical configurations of bus speed and size.
    Jun 11, 2009 | Computers & Internet
    Will this ram support my motherboard?
    your motherboard supports • Supports DDR2 533/400 DDR SDRAM DIMMs
    • Accommodates two unbuffered DIMMs
    • Up to 1 GB per DIMM with maximum memory size up to 2 GB
    that ram may or may not work, most likely not as the motherboard was designed for slower memory.
    Apr 10, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
    Have got a Kinsgton 1GB PC2 - 5300 CL5 240 - Pin DIMM DDR2
    You're not giving enough information to make that decision. Is your PC5300 a 667MHz stick? A better way is to go to crucial.com and let the website analyze your system and let you know what RAM is suited for your system. It is done automacially.
    Apr 09, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
    SAMSUNG 1GB RAM 400MHZ PC3200
    RAM has to be
    Four 184-pin DDR DIMM sockets
    Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
    Maximum HP/Compaq approved memory module is 1 GB
    Maximum HP/Compaq approved memory is 4 GB
    It has to be the same.
    • If you are replacing a memory module, put the
    new memory module in the same memory slot
    from which the old memory was removed.
    Or
    • If you are adding a memory module, install the
    new module into the socket nearest the
    preinstalled module, and install additional
    modules in the next available sockets
    Jan 14, 2008 | Computers & Internet
    EliteGroup P4M800PRO-M2 (V2.0) Motherboard Logo
    547 people viewed this question
    Top EliteGroup Computers & Internet Experts
    David
    David
    Alun Cox
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
