Question about ASUS CROSSHAIR Motherboard
Post shows cpu initiation but stays there
Post shows cpu initiation only
no monitor,keyboard
new DDR2, new CPU, new graphics card
600 watt power supply
  • 67 Answers
So you mean there is a beep when its starts? How do you know there is no keyboard?
Posted on Sep 20, 2008
WHAT POWER SUPPLY RATING DO I NEED TO RUN A A74 ML-K MOTHER BOARD WITH usb keyboard mouse printer SD Card reader
Hi, the download site for your mainboard is here:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000491
I would say 400 watts.
It depends how big your cpu is. 400 watts is ok
with a dual core.
If you planning to add a bigger cpu or a graphic card
you must have at least 600 watts psu.
Sep 08, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
ALL I GET IS A CONSTANT BEEP ON START UP. NO MESSAGES JUST FAST BEEP
It is common for most motherboards to beep to let you know
that something is not right: for example, missing/incompatible
RAM modules (or RAM modules not properly installed) or
missing Graphic Card or CPU improperly installed or overheating
beyond specs...If it's a new motherboard, lay it out outside the
case, installed with the minimum one RAM module, a Graphic Card
(if no built-in Video), the keyboard and mouse. Plug in the power
supply and CPU power coonectors and make sure you can post it
without any error. If there are, check your CPU and its socket, check
for thermal grease. Check for properply installed RAM module. Check
for Graphic Card if any. Of course, assuming that all your components
are compatible with your motherboard (consult user's manual or
manufacturer's website)
Jul 12, 2011 | Intel Motherboard, G33, Core 2 Quad, MATX,...
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Recommended psu wattage inreplacement to 300watts psu for asusp4p800s-x
the needed wattage is directly linked to the componets you want to use other then the mobo itself. the main power surges are the CPU (takes 40 to 110 Watts) a graphics card (from 5 to over 150 Watts) the Drives (about 25-30 Watts eachs), the RAM and all the other addons and gadgets you build into your PC. Just add the different Wattages together and give it quiet some headroom. I usually drive this kinds of mobos with 400-550 Watts PSU to be on the save side, if i use a more or less "standard" graphics card, and even more with high sophistcated cards or lots of drives or such.
if you "see" low power (Volts) it might also be a problem with a partwise defective PSU.
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Palit 9600 1gb ddr2
pls see that yur cpu or gpu is not heating. the power supply may be the culprit. if u have less than 450 watt psu u may consider upgrading to a 600 wall psu.
Mar 05, 2009 | Palit Microsystems GeForce 9600 GT, PCI...
Post
hi i also have a crosshair mobo and it will not post or start up if the internal blue led's are on switch them off on the back and i'm sure it will start
Aug 24, 2008 | ASUS CROSSHAIR Motherboard
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
No display on monitor
Can be a problem with any of the components.
Do the power supply, cpu fan and disks start to spin after power up?
Does the PC speaker sounds a sequence of beeps? Can you identify a pattern, like 3 short beeps indicates a memory problem.
Keep posting so we can zoom in on the problem.
Dec 28, 2007 | Computers & Internet
ASUS CROSSHAIR Motherboard Logo
199 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
