Question about Nikon D80 Digital Camera with 18-135mm Lens
Automatic numbering of pictures using Nikon D80
I have a Nikon D80 and want to have more than one memory card to use with it. How can I make sure that it will keep "numbering" the pictures consecutive between the two cards and not just like 1-499 on each card? Windows will tell me you already have number 499 do you want to replace it when adding to a folder. any suggestions
thanks
barb
  • tylerjohn12 Sep 25, 2008
    Actually went to Nikon website and found it ,, menu and then set up select number sequentially.
  • 7 Answers
Look in the manual. There is a section regarding the numbering of files, which you can do manually.
Posted on Sep 25, 2008
  • Steve McMillan
    Steve McMillan Sep 26, 2008
    Glad you sussed it lol!!
Card is locked
There is a possibility of two problems here, your camera uses an SD/SDHC card which has a slide lock on it I'll give you a diagram for this.
Next thing there is a Custom Set Function I thinks it's number 5 "No memory Card" it's there so you can switch your camera over to make pictures without the card, which to me is not so good because it lets you make pictures without a memory card.
Make sure you have an SD card in your camera and it's been formatted for that camera and change this to "Lock" so you can't make pictures without a card in the camera.
So a quick recap make sure you have an SD/SDHC card in your camera, make sure it's formatted for your camera and take Custom Set Function and change it to "Lock". You should be good to go
Jan 03, 2011 | Nikon D80 Digital Camera
My d80 cameras memory card locked automatically when i insert in
it has a write proctect tab on the on the side of the card when its down the card will be locked ,slide it up to remove the lock.hope this helps pls do let me know
Jun 06, 2010 | Nikon D80 Digital Camera with 18-135mm...
I'm getting the F- - code in the screen of my Nikon D80 SLR. Also, when I press down on the button to take a picture it shows r11 where it shows the number of photos available to take.
i think the f-- code means its not recognizing your lens correctly. make sure all the contacts on lens and camera are clean. the r11 is the buffer. nothing to worry about. The number of images that can be stored in the memory buffer at current settings is shown in the exposure-count displays in the
viewfinder and control panel while the shutter-release button is pressed. This number is updated as photographs are transferred to the memory card and more memory becomes available in the buff er. If 0 is displayed, the buff er is full and shooting will slow. Shooting can continue up to a maximum of 100 shots.
you can get the d80 manual here if you dont have it
http://www.nikonusa.com/pdf/manuals/dslr/D80_en.pdf
Mar 29, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
My Nikon D80 flashes "off" or error and won't take a picture
Is the battery charged?
Do you have a memory card in the camera?
Is the card empty?
Is the lock on the memory card off?
Jul 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 can't take pictures
Be sure you don't have the SD card loked (look at the tab on the SD card itself). You may be seeing CHA or something similar in the viewfiner too.
Apr 24, 2009 | Nikon D80 Body Only Digital Camera
My nikon d60 is starting to take forever to show the picture after taking the photo, and now all the sudden is shows a black box with shooting details on it, i can't get that off!
In your manual you will find how to change the display format (picture only, histogram, etc.). The time it's taking to display your image "might" be that your memory card is getting quite full and you're shooting large images. I shoot a D80 and it uses an SD card. Make sure you but a fast memory card if your camera does not buffer the inage before writing it to your memory card.
Apr 23, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Nikon D80 no picture number in LED & menu not working
Format the SD cards with the camera. You might have to do a software upgrade on the camera since the Kodak card files are different than Nikons.
Mar 29, 2017 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 frame count
264 is the minimum number of shots you can fit onto the memory card. A shot with large areas of black or white uses less memory than a more complex image and so the camera recalculates the number of shots remaining and so the number appears to go back up to it's original value.
Sep 10, 2008 | Nikon D80 Digital Camera with 18-135mm...
Formatting the SDHC Ultra II 4GB in my nikon D80
It shows the number of pictures left, not the size of the memory card...
Mike
Aug 20, 2008 | Cameras
Nikon D80 Digital Camera with 18-135mm Lens Logo
87 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
