Question about Dell Axim X51v Pocket PC
Battery latch Daily readouts that "the battery latch was opened...PDA in sleep mode" has rendered my 32 month old Axim X51v virtually useless. Gentle contact on the back or sides of the machine trigger this. Solutions gratefully received.
  • 3 more comments
  • Anonymous Oct 02, 2008
    I have exactly the same problem!
  • tnite02 Nov 13, 2008
    Same problem where do I find information on how to disable sensor?
    I have same problem. How do I disable sensor? Where is that information?
  • 0Catalyst0 Dec 30, 2008
    I have the same problem. the closest i got to fixing it was taking the back off and putting a little tape on it to hold it down it lasted a little while but hardly a permanent fix.
  • lowkengonn May 14, 2009
    same problem. I cannot even now power on the PDA - rendering it useless. This message started to appear 6 months ago , but did not give much thought .Now power on button cannot even function , even after a reset
    Problem Solver:
  • 10 Answers
This is my 1st posting on this forum although I've done a lot of reading regarding the battery cover I think this is the correct solation.
To everyone that's having problems with the back plate battery cover warning messages or problems not booting up on your Dell PDA, I think I've found the answer, I have 2 Dell's PDA's, 1 a X51v & the other a X50v, I was having problems with both of them (1 had battery cover warning messages & the other had a screen freezing) so I stripped the 2 of them down when I had both rear shells together I noticed that the small piece of sponge that Dell fit to the latching mechanism one was on the far right of the latching plate on one & the other was in the middle of the plate, I looked to see which shell belong to which PDA & the one I was having problem with battery cover warning messages the sponge far right, so I swapped the back shells around & booted it up BINGO!!!!! problem solved, I'm fairly sure the SPONGE SHOULD BE IN THE MIDDLE OF THE LATCH PLATE, if I'm right Dell engineers & executives should be shoot, such a simple fix why didn't they let owners know about this. This has got to be easier than trying to bridge the switch contacts or rip the switch off the board, give it a go guys, Please let me know if it works on your PDA. I will upload some photo should any of you guys need.
welshcob
Posted on Nov 25, 2013
Paper wedged in the sensor sometimes work. More extreme is 'surgically' removing the switch and connecting it up.... see aximsite.com for a guide.... otherwise take it to a technician.
Posted on Sep 26, 2008
Why do I get a battery latch open warning Axim x51v
There is a sensor on the latch that detects when it has opened. Over time, the sensor wears down. You can put a dab of glue on it (so that the button presses down even further) or fold a tiny piece of paper onto it. You can find the sensor right above where the latch is, after you've opened the back cover.
Sep 22, 2009 | Dell Axim X51v Pocket PC
Dell axim x51v pda
You need to do a hardreset on the pda to get the password removed.
Jul 24, 2008 | Dell GG057 for Axim X51, X51v
My dell axim x51v is frozen where says"tap the screen to set up...", nothing happen when tap screen , seems to be in locked position.  Problem started suddenly, after it was charging on craddle ,...
On the left side of the pda is a little slide button with a lock symbol on it, make sure it is slid down. This button is a key/screen lock to ensure you dont push any buttons accidentally.
Jun 11, 2009 | Dell Axim X51v Pocket PC
Dell Axim x51v that will not power on.
Assuming the battery is not dead, try taking the battery out for a few seconds to be sure the PDA is turned all the way off. Put the battery back in and close the back. Use the stylus to hold the reset button in (on the back) while you press and hold the power button. If the battery is dead do this while it is connected to the charger. It should diplay a message telling you to press the mail button (to the left of the cursor control button) to the reset to factory defaults. Caution this will erase everything in the built in memory including any programs you installed after you recieved it.
Hope this helps
Dec 15, 2008 | Dell Axim X51v Pocket PC
Dell Axim x51v
You can get a replacement rechargeable one at batterytrader, here is the link - Dell Axim X51 battery, they also do a couple of extended versions just search on the site, this also fits the dell axim x50 pda batteries
Sep 18, 2008 | Dell Axim X50 Pocket PC
Dell axim 51v
I have the same problem. Its from an over sensitive switch. You arent actually opening the battery case you are pressing against it. This triggers the switch and makes it think you are taking the battery latch off. I haven't actually tried it but you could open up the Axim and cut the cable going to that sensor/switch?
Mar 06, 2008 | Dell Axim X51v Pocket PC
Dell Axim51v Won't power on?
The problem may be that the switch that recognizes when the battery door is on is either not engaging completely, or not working. With the battery door off if you look very closely inside the LEFT pocket that latches the cover (to the left of the sliding latch button) you will see there is a tiny rectangular raised spot in the bottom of that pocket, at its right end. You will not see that in the right pocket. The bottom of the left pocket will move up and down slightly, as does that raised bump upon it. I believe the actual battery cover switch is UNDER that left pocket. To prove it, I tried to turn on my X51 with the cover removed, and it won't come on. Then (requires a bit of acrobat1.gif here) I carefully pressed upward against the apparent switch activator with the tip of a letter opener, while holding the Axim so I could see the screen, and pressed the power button. It instantly came on. I release the letter opener, and it instantly went black again.
Jan 20, 2008 | Dell Axim X51v Pocket PC
Dead - no response
Hi, I am looking for a battery related problem solution on my own Axim X51v, but it is different than yours. One thing I wanted to share with you is that I know if the battery cover lock button is not in the locked position (slid to the right) it activates the "battery door switch". I have occasionally received error messages on the Axim when I turn the screen on and it has missed sounding an alarm. it will say "the battery door switch was open, so the system was put into "sleep mode" to preserve data from being lost" or something like that. So I believe that the position of the latch is crucial. In my case, I think the switch gets dirty. When I get the warning, I slide the switch back and forth a few times and then it stops bugging me for sometimes several months.
So, if you do not have the cover on, then your latch is probably open, and the door switch will be sensed as open. I am not sure what Sleep Mode really does, but I'll bet it will make the Axim appear dead. At the very least, try sliding that latch back to the right. However, I would replace the door, because only friction actually holds the battery in place unless the door is on. It could fall out when you least expect it. Then I think you would lose any unsaved data, and if your internal backup battery was not up to the task, you could lose everything. I hope this info helps you out.
I'll go post my own problem now.
Oct 25, 2007 | Dell Axim X51v Pocket PC
Dell Axim x50v - Battery Latch Problem
Hi Guys
Here are some photo's of the before & after showing where the sponge will be when your Dell PDA is faulty (not booting up or battery latch warning messages & where it needs to be repositioned to, the photo's should be self explanatory, I used some double sided tape to refix the sponge but super glue might work but don't blame me if it runs into the latch mechanize & gluing it up for ever, this does really work & better than messing about with the PCB. I have posted more details on this forum just search for the title ""Why do I get a battery latch open warning Axim x51v"
Welshcob
Sep 09, 2007 | Dell Axim X50v Pocket PC
Dell Axim X51V
I have the same problem. I've found that the Innopocket magnum case will hold the cover in place and pretty much stop it doing this. Unfortunately, the case won't fit if you have an extended battery. I've tried taping down the cover with some success, but the hard case worked better.
Jan 25, 2007 | Dell Axim X51v Pocket PC
Dell Axim X51v Pocket PC Logo
836 people viewed this question
Alun Cox
