Question about Microsoft Windows Vista Ultimate Edition
Installation to the vista,oracle 10g
Sir i need to instal oracle 10g software to microsoft vista (home edition)
Fastinnerhtml!
Posted on Sep 24, 2008
  • 59 Answers
Go to systemaxpc.com look up your driver on the downloads page. download it and save it. open the zipped file look for setup and viola you'll have it
I installed oracle 10g express edition.now I dono how to remove it. please let me kno how to uninstall it.I even stopped the oracle services but i dino abythin further.
Follow these steps:
  1. Open the Windows Services utility: From the Start menu, select All Programs, then Administrative Tools, and then Services.
  2. If any of the following Oracle services exist and have the status Started, then select each of the services, and click Stop:
    • OracleXE
    • OracleXETNSListener
    • OracleJobSchedulerXE
    • OracleXEClrAgent
    • OracleMTSRecoveryService
  3. Exit Services.
See also the Microsoft online help for more information on stopping services.
7.2.2 Step 2: Remove the Oracle Database XE Registry Editor Settings Follow these steps:
  1. Log on to Windows with Windows administrative privileges.
  2. Ensure that you followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop the Oracle Database XE services.
  3. Start the Registry Editor at a command prompt:
    SYSTEM_DRIVE:\> regedit
  4. Go to HKEY_CLASSES_ROOT.
  5. Delete the following keys:
    • NEED TO CONFIRM THE XE-SPECIFIC ONES.
  6. Go to HKEY_CURRENT_USER\Software.
  7. Under Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu\Programs, delete the Oracle Database 10g Express Edition key.
  8. Go to HKEY_LOCAL_MACHINE\SOFTWARE and search for the ORACLE group key.
  9. Expand the ORACLE group key and then delete the KEY_XE and OracleMTSRecoveryService keys.
  10. Go to HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI.
  11. Expand the ODBCINST.INI key and remove the Oracle in XE key.
  12. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services.
  13. Delete the following keys:
    • OracleServiceXE
    • OracleXEClrAgent
  14. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Application.
  15. Delete the Oracle.xe key.
  16. Exit the Registry Editor.
  17. Restart your computer.
7.2.3 Step 3: Update the System Variable Path Follow these steps:
  1. Open System from the Control Panel.
  2. In the System Properties dialog box, click the Advanced tab, then click the Environment Variables button.
  3. Select the system variable Path and edit the Path variable to remove the Oracle Database XE entry. For example:
    C:\oraclexe\app\oracle\product\10.2.0\server\bin;
  4. Save your changes and then exit the Control Panel.
7.2.4 Step 4: Remove Oracle Database XE from the Start Menu and Desktop Follow these steps:
  1. Select Start, then All Programs, and then Oracle Database 10g Express Edtion.
  2. Right-click Oracle Database 10g Express Edtion and from the menu, select Delete.
  3. On the desktop, right-click the Get Started with Oracle Database 10g Express Edition icon and from the menu, select Cut.
7.2.5 Step 5: Remove the Oracle Database XE Directories Follow these steps:
  1. Ensure that you have followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop all Oracle Database XE services.
  2. From the Windows Explorer, navigate to the directory where you installed Oracle Database XE, for example, c:\oraclexe.
  3. Right-click the Oracle Database XE installation directory and from the menu, select Delete.
7.2.6 Step 6: Install and Run the Windows Installer CleanUp Utility Run the Windows Installer CleanUp utility to remove the Windows Installation configuration information for the Oracle Database XE installation. You can download it from Microsoft at:
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
he deinstallation completes, click Finish.
Sep 14, 2010 | Oracle Database 10g
I want to install oracle 8i in windows 7, how i do this?
sir, i have a window7 in all in one hp but there is a software called mstar which run on oracle 8i when i install the oracle 8i there is a problem and show dll file corrupted. Pls tell me the solution because my client want it very urgently and i am not able to install and run the programm.
Feb 26, 2010 | Veritas Cluster Server for Solaris Oracle...
How to install oracle 9i in vista ?it is not supported.
Your best bet is to look on metalink and search for the error code you are getting. Oracle is very particular about what versions work with specific OS's
Oct 03, 2009 | Microsoft Windows Vista Ultimate Edition
Uninstalling oracle 10g from vista
To uninstall oracle from your PC,
first you should run the oracle setup from the installation disk.
The installation setup will automatically detect the oracle products installed in your PC.
After checking the list of installed products, mark the programs you want to uninstall & then click on uninstall.
Apr 11, 2009 | Oracle Database 10g
Problem to install oracle with vista homebasic
you are correct first read then install exatly problem soloving
vot
Apr 01, 2009 | Microsoft Windows Vista Ultimate Edition
I didn't know how to uninstall oracle 10g enterprise edition.
Dear sir
Please do the following.
start>run> ( please type services.msc)
in services window you can find some oracle services.
please stop all the services by right clicking.
after that you can uninstall the oracle software.
again you can reinstall the oracle.
please vote.
regards
murali
Feb 15, 2009 | Oracle Database 10g
ORacle 8i on Windows Vista
You wont be a ble to install Oracle 8i to Vista computer ,because that Oracle version is not supported on that Vista OS (only 10g onwards) will work with Vista computers.
Hope that helps........
Sep 12, 2008 | Computers & Internet
Uninstall oracle 10g database
hve uninstalled oracle 10g from xp!! but still one program is left over say oracleserviceXE, that i could not find!! how to remove this, to install the s/w again!! plz kindly help me regarding this
Jun 01, 2008 | Computers & Internet
Can we install Server component in Vista Home Basics
I see no reason why you cannot do so. Just make sure you find all the drivers for you laptop before you migrate.
Apr 18, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
127 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
