Question about HP PSC 2355 All-In-One InkJet Printer
Printer repeatedly giving Out of Paper message, pile of gunge under cartridge
I have been getting a repeated "Out of Paper" message from my printer although there is plenty of paper in the stack. Originally I thought it was due to card I was printing on but even after a reboot, a clean of the rollers, it has the same probably with ordinary 80 gsm paper. I had recently changed both print cartridges so I checked that they were seated correctly. When I removed the black print cartridge I noticed a column of black ink underneath it. On looking further the black inky gunge was pretty well distributed under the ink cartridges and around the area. I always always buy new genuine HP cartridges! What can have caused this, could it be causing my paper low issue, and how to I stop it happening again. I'd like to know before I put my printer back into operation.
  • jc53 Sep 26, 2008
    I could have written Josie48 's post. I'm having the exact same problems - out of paper message, pile of gunge, thought it was from printing on card stock etc.
  • Adannyjohn Nov 26, 2008
    printer gives out of paper message. it is not out of paper
I still don't know what is causing the ink cartridge to leak (I'm assuming that is what is happening) but after cleaning up the area around with lint free wipes and cotton buds (and rubber gloves!), the problem has gone away. I presume the mess had been affecting the sensors causing the false paper low condition.
Posted on Sep 27, 2008
I get the message "printer error has occurred" and please turn the printer off and on repeatedly with no change. This is the Epson Artisan 835
My Epson Artisan 810 repeatedly would give me the printer error message with the only option to turn off the unit and turn it on again. Over and over it would give me the printer error message. With the unit off, I opened the cover (like you would to replace the ink cartridges) and forced the CD tray all the way out like you are about to load a CD for printing, closed the cover, then started the unit up again. For me that did the trick. It went through it's normal 60 seconds or so of set-up, then worked fine ever since. Not sure if this will work for you, but it worked for me.
Dec 29, 2012 | Office Equipment & Supplies
Top light blinking. Getting paper jam error message repeatedly. Cleaned the pad. did a nozzle check, replaced THREE cartridges. Did not give my blood type yet. How to fix? The waste pad is not...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Feb 18, 2011 | Epson Stylus Photo R2400 InkJet Printer
Remove and check cartridge
Step 1: Remove, inspect, and reset the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat repeating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step : Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
NOTE : you can also check the print cartridge label and make sure it iscompatible with your printer. Compatible print cartridges are listed inthe Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
Jan 04, 2010 | HP OfficeJet 6110 All-In-One InkJet...
C4150 Is stuck on or continues to repeat out of paper
probably you have jam paper check if the printer do not have paper on it or go control
panel and delete the printer and then installed again
Aug 15, 2009 | HP Photosmart C4150 All-In-One InkJet...
Repeat warning
Have you tried removing/re-inserting the ink cartridges??
May 16, 2009 | HP PSC 2355 All-In-One InkJet Printer
Paper jam message, but actually no paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 25, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper jammed. Remove jammed paper and press the printer's RESUME button.
give this a try
alternative :
Dec 15, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Paper jam notification after printing one page, no paper jam
try this
alternative :
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper feed problem
usb port or printer adapter problem.check both of them.wish success
Jun 04, 2008 | HP Deskjet 2360 InkJet Printer
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
106 people viewed this question
Seeker5211
Seeker5211
