Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher running but no water is being pumped in.
Hi
There was a layer of water at the bottom of my dishwasher 2 days ago. I followed some online instructions and opened the left hand screw on the metal plate and managed to get some pips and a small piece of glass out of the small filter/grate.
However, now when I switch it on, the engine sounds like it's running, but no water is pumped in and the plates are dry.
I've read that it might be caused by the 'floater' and that the 'floater' needs to be in the 'up' position. BUT...what is a floater and where is it?? What do I need to do to get to it (unscrew screws etc).
I don't know what model my Bosch is as I can't find a model number anywhere on the machine - it's built into a cupboard.
Much appreciated.
Lee
  • Sharon V Sep 30, 2008
    I have the same problem. We received a 2nd hand Bosch Hydrosensor dishwasher which was in perfect working order, however after transportation to my house and connecting all pies correctly, it runs on the cycle but does not fill with water. We have checked the black hose and the filters. It runs when you manually put water into the machine, but it doesn't take fresh water in. Convinced something must have happened during transportation. HELP!
The model number is laser etched into the top of the inner door if you shine a torch across the top you should be able to read it sometimes they are quite faint,all bosch dishwashers are fitted with an anti flood device triggered by water in the base appliance will only drain out and do nothing else the water needs to be drained out. the easiest way is to tip the machine backwards with a towel on the floor to collect the water( will be about a pint!) or if you leave it stood in a warm kitchen after a few days the water will evaporate and appliance will start up again.
Posted on Oct 05, 2008
  • 4 Answers
Water under  unit turning of float switch.
Posted on Oct 03, 2008
My Professional series dishwasher does not work properly. It is only 1.5 years old and glasses on top rack get sprayed with fine layer of particles every time I use it. Other items, top and bottom, are...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jgkljhk;
Mar 13, 2010 | Frigidaire PLD4375RFC Dishwasher
Pump still going. Dishwasher flooded last week and pump still going every time i switch it back on. I have left off for 3 days and I have tried the reset.
Check the following:
You'll need to get the water out of the bottom of the dishwasher - a wet vac usually works the best.
Remove the bottom rack and check the pump inlet screen in the bottom of the dishwasher for debris - it would be best to remove the screen and look for anything that may be preventing water from entering the pump.
The sink, at least the side where the dishwasher drains to be sure it isn't plugged
The discharge hose from the dishwasher to be sure it isn't obstructed somehow - you may to remove it to be sure. Check the discharge line check valve assembly to be sure it isn't stuck with something
You could have a control board issue, but if the pump is running, it should pump.
Jan 05, 2010 | Dishwashers
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Soap problems
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some (quite some) water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Oct 21, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher not pumping water
anti flood mechanism activated in base pan you have a leak once the anti flood is activated in puts the machine into permanent drain thats why it runs even with the door open but only runs the drain pump not the wash pump.
Mar 01, 2017 | Bosch 24 in. SGI43E05GB Built-in...
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Sounds like dishwasher is running but no water coming out (there are no broken pipes or leaks)
I had the same problem. The motor is working (humming) and my dishwasher goes through the whole cycle without water. I googled it and found it on a website. Sorry I don't remember which website. Basically, it said to put some hot water in the bottom of your dishwasher and add some citric acid. I added 2 small packets (2 oz each) and filled the bottom of the dishwasher with hot water until it covered the motor or the drain of the dishwasher and left it overnight. The next day my dishwasher started and ran perfectly fine. That was over 4 months ago and I have not had any problems.
Mar 24, 2008 | Dishwashers
Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Mar 20, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
FDW60 dishwasher
I've just (as of 10 minutes ago) had the same problem. I followed the advice given elsewhere in this forum and removed the bottom cover - water running out so needed a big towel to mop it up. I stood the machine upright and restarted it - no problem! it started straight away.
The question now is where is the water coming from? It seems there is obviously a leak somewhere and water is gathering in the undertray setting off the microswitch.
Oct 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
237 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
