Question about Nokia 6300 Cellular Phone
Tone set up
When i turned my tone set up, it automatically turned off but other programs are fine aside from the tone it is not functioning.
  • Nokia Master
  • 1,800 Answers
U need to upgare the firmware of ur phoen or Flash it using a box cost doule of ur phone so best advise take it to the market guys and tell them just flash my phone so they will not cost u lot cuz u already gave them the diagnotise
Posted on Sep 21, 2008
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
How do I set dial tone on line 3?
If you mean for line 3 to be selected when you pick up the handset, you need to program that as the "prime line" for that set.
Sep 30, 2015 | NorStar M7310 Corded Phone
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
How do you program #s into the machine? can't
Your machine will only injser a # if the telephone line settings is set for tone dail.Press dataregistration,press set and scroll to usersettings scroll to tel line type and set it to tone.
Dec 02, 2009 | Canon LaserClass LC 8500 Plain Paper Fax
No programming tone
On page 11 of the manual:
Disabling the timer reminder tones:
To disable the reminder tones, press and
hold the Timer Set pad for 5 seconds. To
enable the tones, follow the same step.
To shut off all (audible) signals except for error tones and the hidden function signal:
Press and hold the Stop Time pad for5 seconds. A short tone will sound to tell you the signals have been changed. Repeat the above step to turn the signals back on.
If that doesn't work, the next thing I would suggest is a hard reset. Unplug the unit for a minute or so.
Then plug it back in, set the clock and try again.
Dec 03, 2008 | Whirlpool RMC275PD Microwave Oven
Nokia 6300
when i turned the tone set up for the profile of my china nokia phone (6300) it turned off and my tone set up is not functioning. but other programs are all doing fine. what will i do?
Sep 17, 2008 | Nokia 6300 Cellular Phone
Nokia N70 problems with phone ring
There is an sms ans ringtone pach on niokia n70 website. Try those
Apr 10, 2008 | Nokia N70 Cellular Phone
Keypad tones - D900i
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Oct 07, 2007 | Samsung SGH-D900 Cellular Phone
Nokia 6300 Cellular Phone Logo
20 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
