Question about Conair Compact Garment Steamer Iron
When i am ironing all the power in the house goes off and it is a brand new iron
  • LT Hissy Dec 08, 2008
    I have the same problem! The iron is new, I'm not using an extension lead, and haven't installed the plug myself. It has happened every time I have used the iron (about 6 times), and today I broke a new record - 6 power outs during one ironing session. The iron is a Sunbeam Ultra 55 Platinum.
    I'll try it in a different room next time.....
  • 818 Answers
Patrick,
The iron may actually be ok. If not, remember that because it's new it will come with a guarantee.
Did you put the plug onto the iron yourself? Check inside the plug to make sure that there's no bare wires that can touch as the cord flexes as you iron. This would cause it to short and throw the power in the house.
Try using the iron in a different room. If you get the same problem then there's possibly a wiring fault (maybe a broken/worn insulation on the wires of the iron cord ... though as it's new, I would doubt this).
Are you using an electrical extension lead to plug the iron into? If you haven't overloaded the socket with other electrical appliances it may be that the extension cable has a broken/faulty/loose wire inside that when they touch, causes the power to go off. A few years ago the power in my house used to go off on occasions whenever someone went to the fridge. The fault was traced to split insulation on one of the wires in the extension cable I was using. Whenever somebody stood on the cable it shorted out and cut the power.
To be really sure - go into a neighbours and use the iron! If the power goes off - it's the iron at fault. If not, it's probably just a small problem like worn insulation/loose/broken wire in an extension lead in your own house.
Posted on Sep 19, 2008
Power up problem
Would probably be best to buy a new iron, not powering on, would indicate a internal problem, really in my opinion it would be best to buy a new one. without knowing more about the iron you have..
Jul 22, 2008 | Irons
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
My iron trips the safety switch and causes a blackout of a third of the house. Is there anywhere I can get it checked for free? I live in East Fremantle, Western Australia. It cost $130 about 12...
This must be easay if you have a multimeter to check, The power plug must have a clean continuity to the coils of the iron. It is possible that the cord is short and so the short seems to make the circuit trip. To confirm remove the main power cord from one end and check for short in the wire. If the mains and neutral shows a short with one wire taken off from the iron then the wire is short. If not the short is within the iron that can be checked in the similar manner.It can also be a very minor problem of a wire sticking to short within in the control.
There are many good brands, Philips, Rowenta,Black and Decker, Panasonic etc.. choose one which suits your need.
Jan 11, 2011 | Philips Irons
Euro Pro Irons: Less than a year old stop heating up.
hello,
some time no part of our property go bad but what will need is to service them from there dysfunction
the problem of your iron could be from the element and the wire ,the element is the heat provider while the wire is the power supply from the electric
But the fact is that ,the problem of your iron is disconnection of element from the wire what you need to do fix it to unscrew your iron and trace the wire down to the element and see the disconnection am toking about and fix it back
thank you and thanks for using fixya.
May 31, 2010 | Euro-Pro Shark GI490 Iron
Brand new iron and it wont heat up over 140 deg F.
Contact B & D and they will probably replace it - they will need the receipt.
Mar 01, 2010 | Black & Decker Classic Metal APP F63D Iron
Power won't come on
You have a short in the cord. If you knew where the short was, you could possibly repair it. However, I would strongly suggest buying a new iron. An iron is an appliance that can burn your house down even when it's in GOOD working order. You should be able to buy a decent iron for around $30, and I would say the peace of mind alone would be worth it. Hope this helps,
Chad
Oct 08, 2008 | Rowenta Professional DE880 Iron
Just stopped heating
Unless you have a 5 or 6 hundred dollar iron, there is an excellent rule of thumb when an iron quits working. Buy a new one. These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Oct 04, 2008 | Toastmaster 3302 Iron
Rowenta won't shut off automatically
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 30, 2008 | Rowenta Professional DE880 Iron
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
Conair Compact Garment Steamer Iron Logo
118 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
