Close Disc Alba RDVD1001 NO MANUAL
Please help. I don't have the manual for the Alba RDVD1001 and I cannot figure out how to close a disc that we have recorded to play in another dvd player. Please help as one of the discs that we cannot play is a dear friends wedding!!!!!
Try going to "Edit Disc". That should close it for you.
Posted on Jan 28, 2010
My RCA RTD 206 5 disc changer wont play DVD's. It stays on Disc 3 or just says close. I called the # in the manual foe help, but its no longer in service.
If it plays the same disc without issues, you have a mechanical(or the electronics powering the motors and such) problem. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
How do I eject a disc from a dell sdudio one
Removing a disc with the computer off
To remove a disc with the computer turned off:
1 Insert a slender object, such as a straightened paper clip, into
the manual eject hole.
The disc tray slides partially out of the drive (about 1 inch).
Never use a pencil to press the manual eject button. Pencil lead can
break off inside the computer and damage it.
2 Pull the tray out until it is fully open, remove the disc, and
place it in its protective cover.
3 Gently press the tray in to close it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 26, 2011 | Dell Studio One 19 PC Desktop
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
H03 Error & Disc Tray Error
Most likely the tray for your player came out of aligment, this happens when someone pushes on the tray to close it, instead of using the "Open/Close" button, you need to take it to somebody to realign the disc tray.
Jun 13, 2008 | Panasonic DVD-RP56 DVD Player
How do you put on a dvd?!
i take it all set up the dvd to tv.?
turn on the dvd player with the remote .
press open on the remote
insert the disc dvd out of the box
close tray
press play to watch dvd
when finished
press open take out disc and close disc tray and turn off dvd player .
riz.
May 24, 2008 | ASUS DRW-1608P2S DVD RW Dual Layer Burner
PS2 auto shut down when disc tray is close
big mistake. never use ps1 cables on a ps2. i made the same mistake once.
Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
Open message when closed/disc wont spin
I figured it out, it was the little plastic sensor stick that tells the unit that the lid is closed therefore reading the disc. cheap piece of plastic that has surely snapped on many a unit. good luck replacing it. i rigged it though problem solved
Sep 16, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
Televison & Video Logo
380 people viewed this question
Top Televison & Video Experts
