Question about SanDisk Sansa Clip MP3 Player
Sansa clip says i must free 4mb then switches off
When i switch on my sansa clip 1gb player,a message appears on the screen saying[ NOT ENOUGH SPACE FOR MUSIC DB.PLEASE FREE 4MB]then it switches off.all the other buttons are not working and i cant access anything from it.it all started when i was recording on the FM radio.please help me.email to mhanduallen@yahoo.com the solution.
  • 2 more comments
  • plaincrazy Sep 23, 2008
    i have the same problem with my sansa clip. when i turn it on it says not enough space for music db. please free 4mb
  • rolldub79 Sep 24, 2008
    I added some MP3's and then all of suddent it said the same problem except for 30mb
  • tynumi Oct 01, 2008
    thanks,it worked.
  • swije002 Dec 08, 2008
    My Sansa Clip 4GB gives me a message saying that there's not enough space for music db, and to free 30 mb everytime I turn it on, and then it immediately shuts off. How would I go about deleting enough space? I tried using Windows Media player to delete the files, and also tried going on My Computer, but it registers the clip as a removable device, and doesn't register it as its name. I couldn't figure out a way to delete the files. How would I go about doing so? Thanks!
  • 758 Answers
You should format the device using windows media player or the device itself..that should fix the problem you are having..remember formatting will delete all the date you have on the device..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Sep 25, 2008
Wont turn on, plug it into comp reads...not enough free space for music DB please free 30MD. my computer does not recognize there is even anything pluged in. the clip says its connected and charged. how do...
Slide the Clip's power switch to the "lock" position, then hold down the rewind button (looks like "<<") while plugging your Clip into the computer. You should then see your Clip show up in Window Explorer as a "removable disk". Right-click on the Clip in Windows Explorer and select "Format". Don't select "Quick Format", and be SURE you're doing this to your Clip, not one of your computer's disks.
After the format is done, unplug the Clip, plug it back in and verify that you no longer get the "not enough free space" message.
Jan 26, 2010 | SanDisk Sansa Clip MP3 Player
Sansa m230
When connected to your computer, go to your My Computer folder, and right click on your Mp3 player. You should see "Format Device". This wipes the entire thing. All music will be gone, but it might reset it.
Jun 02, 2009 | SanDisk Sansa m230 MP3 Player
Sansa m230
so your mp3 player is full of songs. you dont have enough free space to run the mp3 player or put anymore songs on it. so delete a few.
Apr 19, 2009 | SanDisk Sansa m230 MP3 Player
(urgent) please help me i really need it
Reformat the player in Windows Media Player - reconnect it to computer, open Windows Media Player, bring the drop down menu up underneath the Sync tab - click on the Player name, and then format.
Apr 16, 2008 | SanDisk Sansa Clip MP3 Player
help me please
"Not enough space for Music DB. Please Free 4MB"
Corrupt database - upgrade the firmware from www.sandisk.com
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 31, 2008 | SanDisk Sansa m250 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
When you delete files on the sandisk it just moves them to an invisable folder labeled .trash inorder to free up some space you need to delete the files inside this invisable folder. if you are using windows then plug in the device and open it. go into you folder options and make sure it has show hidden files selected. If you are using a linux os then go into your view menu and select show hidden files. this should make the .trash folder appear. hope this helps.
Jan 26, 2007 | SanDisk Sansa m230 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
207 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
