Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Intuitive eco - no power
Machine was filling, there was a loud pop/bang and now the machine has no power and will not turn on. Other appliances work on the same powerpoint
    Problem Solver:
  • 6 Answers
Definately need to get a service man out. Sounds like the computer board has failed & the tech will need to check if another part was the cause of the board failure.
Posted on Sep 22, 2008
Eco intuitive error 40
Your machine cannot detect correct water level
The clear pressure tube has come off or got a hole in it somewhere.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Have older machine always worked with no problem ....it is and FandP Intuitive top load.. today put in light load started off machined filled and stopped....now nothing is happening not even any lights....
If machine is completely dead ie no lights, then you probably have a faulty motor control module (main power board). These do not have any replaceable fuses, requires new module. Note- fault could be with another part of machine, which has caused module to fail eg faulty drain pump can blow control module. All other components need to be testedd before module is replaced, preventing a new module from blowing due to a fault elsewhere. These can be quite a complex machine, and not really easy to fix by untrained persons. Recommend calling service technician
Jul 31, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel intuitive eco - code 12 Water keeps running and I have to keep turning of the machine and water supply. Please help!
The solenoid on one of the fill valves, in the washer, is probably stuck open. Only fix is to have it replaced.
Jul 11, 2009 | Fisher Paykel Eco IWL16
Intuitive eco w.machine showing error code 130 and sometimes 240
switch the power off for a little while minute or 2 & turn it back on and press the power button and pstart the cycle again.
Apr 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
IW811 Loud Noise During Fill Cycle.
Peace Friend,
ngfam1 At your service!
SOUNDS LIKE THE BELT IS SLIPPING !
My advice is to call a trained tech.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Jul 03, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
263 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
