There is one screw on the bottom that must be removed to take the DVD combo drive out. When I remove the DVD combo drive, I like to remove the Hard Drive first so that I can push on the back of the drive with a small screw driver through the hard drive bay and not pull on the face plate. You can also open the drive first before turning it off or use that small hole on the front of the faceplate to open it when turned off...then you can pull on the side rails of the drive to get it to come out.
If the burner is a combo burner it can do both it will tell you on the face of the burner. If this is not the case it will just burn what it is meant for. You cannot do both if it is not a combo burner. One or the other combo both. You will also need burning software as well. One of my favorite free burning software programs is XPBurner it does it all and is really easy to use. Thanks for using FixYa! John
If it is a direct replacement drive, exact size as old drive, then all you need to do is remove the old cd drive and slide the new drive into the slot until the back plug engages. Install new drivers as needed and any software that came with new drive. Hope this helps.
Thinkpad T30 are usually supplied with the following optical drives, CD ROM, CD R/W, and Combo DVD ROM with CD R/W.
You most likely have the Combo drive, therefore you can play DVD and CD disks plus burning music and data onto CD-R and CD+R discs.
You need CD burning software such as Roxio Easy CD Creator or Nero. Both these programs are excellent and easy to use.
I don't mean to disagree with my associate, but DVD players for R series (or T, A, etc) can be found for less than 20.00 US (Ebay is a good example)
For that matter, we've got at least a dozen at our shop which we sell for 25.00
Installation is very simple as well, just pop the old drive out, put the new drive in.
Good luck
