Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
My computer won`t display
I was running one application(fifa 2004) on my computer & It just frooze i switched it off & when i turned it on again it ran but did not display on the output unit.Is it my processor or my video output jack that has a problem.
  • sfisok Sep 22, 2008
    response to Krkchn,No I do not hear any Beep
  • abeochoa Dec 01, 2008
    after installation i try to load and it wont.
Krkchn,I think I`ve found out what the problem is:I`ve connected my cpu to a different motherboard,The motherboard turns on and then off at random times.when i remove the cpu from the socket it feels very hot.I think my cpu could have overheated and mybe that could have affected the motherboard too.
Posted on Sep 23, 2008
  • 67 Answers
Do you hear a single beep when it turns on?
Posted on Sep 20, 2008
  • Kirk Philipson Chan Sep 22, 2008
    That is a complex problem and is probably the fault of the power supply which may have eventually taken out the motherboard as well. Are the computer fans running? If not, replace the power supply, the motherboard may still be good. If it is running, your motherboard could be damaged. If you want to further test the motherboard, better find a known good power supply as not to damage further the motherboard.
How to access computer?
Turn the Ignition switch to the OFF position.
Set the Run/Stop switch to the Run position.
Push in the odometer reset button and hold.
Turn on the ignition switch and release the odometer reset button.
The process has been completed correctly when the speedometer needle sweeps across the speedometer and all indicator lamps illuminate. The speedometer will also display "DIAG."
Press the odometer reset button once. "PSSPt" will display on the speedometer. Each letter signifies an area of the diagnostics testing, with the current selection flashing.
Push the odometer reset button to scroll through the components for testing.
Press and hold the odometer reset button for 5 seconds, then release. Any codes stored will be displayed on the speedometer. If no codes are stored, the speedometer will display "NONE."
Press the odometer reset button again to view additional codes, if any.
Record the codes and repost for possible faults or conditions.
Turn off the Ignition switch to exit the diagnostics testing.
Sep 18, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
My 2004 would cut off at idle,but start again after a min or so. But time it ran and cut off after a mile. Now it won't start at all. Won't turn over. It will move somewhat when I turned it by
No.
The crank sensor tells the computer when number one cylinder is at top dead center to find the timing for the spark plugs.
If the engine will not crank with the starter, the starter, key switch, battery or cables could be faulty.
Some of these items could also cause it not to start.
If the engine is stuck you won't be able to turn it at all.
Jun 28, 2012 | 2004 Jeep Grand Cherokee
My Volvo s60 won't start replaced battery and starter and still won't start battery test fine what can I do I have good power throught out
you will need to try to turn the engine manually to make sure its not frooze. if it turns then you might need to check the starter again.
Aug 28, 2011 | 2001 Volvo S60
I have fifa 11 now, buying for 40,., but i can not playing it on my computer, because i have a geforce fx series. please can you help my?? Sorry for my bad English
I don't quite follow the problem but, you have a low end card and maybe the game is too demanding for it. Are you having problems with crashing? Have you updated your driver? You can update the driver here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Product Type-GeForce
Product Series- GeForce 5 FX series
Product-GeForce FX 5500
Choose your operating system, language and click search.
You will want to uninstall previos driverbefore downloding new.
Jun 12, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
When I touch the Scan Menu button, and choose scan to computer I get a message that states: No Scan Options I have been scanning for a year. This happened suddenly and I can't figure out why
Hi
Thanks for using FixYa. Due to any reason when the HP Communications process fails the HP Scan application won’t work. To resolve the issue you’ll need to follow the procedure as given below---
  1. Force Quit HP Communications (if running)
  2. Force Quit HP Scan (if running)
  3. Turn the printer off
  4. Turn the printer on
  5. Select Scan Picture from the HP Director application
  6. When the HP Scan application complains, press Reset
  7. HP Scan will then hang, but HP Communications will restart
  8. Force Quit HP Scan (again)
  9. Select Scan Picture from the HP Director application (again)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 28, 2009 | HP Office Equipment & Supplies
Fifa 09 freezing not running fast
Geforce 7100 is a built in graphics card, so you may not be able to play this game at a high setting. Try lowering the game settings to see a improvement in speed.
Aug 08, 2009 | Buck FIFA 09 for Xbox 360
YOUR CONFIGRATION IS ABSOLUTELY FINE THE PROBLEM IS WITH WINDOWS VISTA. FIFA 09 FREEZEZ IN VISTA EVEN IF U GET A 1GB GRAPHIC CARD. SO WHAT I DID WAS INSTALLED WINDOWS 7 AND TAKE MY WORDS THIS GAME RAN ON FULL RESOLUTION EVEN WITH MY 128MB GRAPHIC CARD. SO IF U R REALLY KEEN ON PLAYING THIS GAME SWITCH TO WINDOWS 7
Aug 08, 2009 | Electronic Arts FIFA Soccer 09 PSP IDE...
Putting a photo onto fifa 09
Not knowing anything about this application, I can say that many of these apps require a JPG of a small size, such that they cannot exceed a specific size. If they do, they won't display, or not properly.
Try making your JPG or video image smaller than 96 dpi by 96 dpi. Also, if you are not using a JPG image, but a GIF or a TIFF, it simply might not want that kind of an image.
May 07, 2009 | Computers & Internet
My mp3 player frooze
Have you tried resetting the player? get a thin paper clip or something similar and push the tip into the hole. then try charging it again untill fully charged, and remove from PC. Good luck
Mar 27, 2006 | Samsung YP-T8 Digital Media Player
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
