I have a Saunier Duval aircon unit SDH 31-035w. It runs for 30 seconds and then switches off and displays the message L6. What does this mean?
  • park_amos Sep 19, 2008
    Thanks
    The unit is only 1 month old so I don't think it's a lint and hair problem. I will call an engineer to check the refridgerant charge.
    Problem Solver:
  • 15 Answers
That code means low pressure.
The unit has either lost it's refrigerant charge or the coil is dirty. Look at the unit and find the metal fins. Make sure they aren't plugged up with lint and hair. There are two coils on an air conditioner, one inside and one outside. It won't hurt to check them both.
If cleaning the filter and coils doesn't fix the problem, it's time to have a technician come and check the refrigerant charge.
Posted on Sep 19, 2008
SAUNIER DUVAL model 31-026. Where can I obtain a troubleshooting manual?
Boiler Manuals: Saunier Duval - Plumbase
https://www.plumbase.co.uk/documents/index/10000204
Boiler Manuals for the Saunier Duval range. ... Saunier Duval Thema Range · Saunier Combitek F23E · Saunier Duval Isomax F28E · Saunier Duval Sylva ..
Aug 20, 2015 | Heating & Cooling
Can I get a manual for a saunier duval instaneous gas water heater?
Yes. Just go through the company you purchased it from for this manual.
Sep 09, 2014 | Water Heaters
Where is re ignition location on saunier duval condens f24 e
Wrong category !! Try question in the correct category !
Dec 19, 2013 | KDS Valiant 6380iPTD-01 Notebook
Boiler pressure saunier duval
Appear to be corroded/plugged inlet valve. De-pressurize system and check inlet valves and line.
May 11, 2013 | Water Heaters
My Kidde Carbon monoxide beeps every 30 seconds and is showing L6 with a flash of 0? It is brand new. What does this mean?
L6 is actually "Lb", which is a low battery warning. If the 9V battery is missing, or if the battery's power is low, an "Lb" message will display, which blink's alternately with the current CO reading, while chirping. If this happens, you need to replace the battery.
Nov 10, 2012 | Kidde Nighthawk Combo Gas/co Detector
Hi, I have a Saunier Duval? Theilea twin 28e
You may want to check the Pressure Reducing Valve On the supply line to the building. Easiest way to check is get a guage that hooks up to your hose bib (usually found in the sprinkler section at your hardware store). If your pressure is getting above 80, you need a new PRV.
Feb 14, 2011 | Water Heaters
Low pressure for SAUNIER DUVAL TERMACLASSIC
there is a blue tap at the bottom of the boiler when you turn it and nothing happends the screw had broken off inside you can do 2 things here put a new filling tap on the boiler , or get a filling loop put some where else on the system and if you still get low pressure replace the low water pressure switch...
Jan 31, 2011 | Heating & Cooling
Hi, Got a Saunier Duval Thema F 23 E and need to repressurise it (currently at 0 bars). can you provide any help on how to do it? Thanks.
http://www.saunier-duval.co.uk/manuals/pdf/noncurrent_products/installation_ThemaF23e-SBF23e.pdf
Here are complete instructions for installation and service including purging air and refilling. One of the first suggestions is that service is to be referred to a competent technician.
Gary
Dec 18, 2010 | Water Heaters
I have a 11 year old Saunier Duval and the hot water hardly works
suggest you call a repair service. gas appliances are dangerous to DIY they explode when people do not use the proper safety precautions
Aug 31, 2017 | Combi Centre DX - Mango
Heating & Cooling Logo
456 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
