PHILIPS TV 28MK2490/73R
STBY FLASHES
F2 ON SCREEN
NO CONTROLS
4 Suggested Answers
  • 668 Answers
SOURCE: tv turns on for one second then turns back off
I believe it is a Back Light failure. Either because of a bad Ballast, a Power Supply, or a bad Lamp that is not replaceable. If it is a bad Ballast or Power Supply they are replaceable. Checking the Voltage from the Power Supply for the Ballast will tell if the Power Supply is bad. It should read around 250V to 300V.
If the Voltage is there, the LCD Panel will probably need to be replaced. I recommend a professional to evaluate it to be sure.
I hope this helps,
Skyassoc
Posted on Aug 25, 2009
ginko
  • 19396 Answers
SOURCE: Philips plasma T.V. model BDS4231R/00 Cassis
Hi.
If the TV keeps shutting down and goes in standby, then the TV is going on protect mode after detecting a malfuncion.
When this happensthe TV gets shut down to prevent further damage to internal components.
Before calling support ensure that you have followed the indications here Why my TV does not start up and remains in standby.
Troubleshooting basically consists in leaving the TV unplugged to drain power completely and discharge internal circuits. Instructions are for a DLP, but procedure is the same with any TV, even plasma TV.
The best way to contact an authorized technician is by ringing the number listed on the owners manual. Alternatively try Fixya directory here:Fixya directory- Consumer Products Repair
Try first the troubleshooting proposed in link above. If that does not work, ring customer service.
Regarding the rpair cost, this depends on the part that is defective. A common fault is the power supply, but this is not necessarily the problem.
If you are a repairer,testing willl start from PSU, following voltages on main board and testic diagnostic points listed on service manual. Here the service manual: philips slc4.3e - Service Manual
For parts try Partstore or ShopJimmy .
Regards.
Ginko.
Posted on Aug 17, 2010
  • 367 Answers
SOURCE: tv won't turn on. Standby red light is on, then
<font size="4"> Did you fix this yet?Please let me know.Thank You very much!<br /> Tyler<br /></font>
Posted on Aug 21, 2010
I have a Philips flat screen TV, Model 50PF9630A/37 i replaced some blown cap on the power supply board now the red light flashes in a sequence of 7 flashes, any assistance would be appreciated.Guy
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
Jan 10, 2017 | Philips Televison & Video
User Instructions for a Philips 14PV 172/05
put it on stby
then push the stop button on the machine and keep it
then push on the rc, the vol- and vol+ at the same time.
goodluck
Apr 19, 2010 | Televison & Video
Tv won't turn on. Standby red light is on, then flashes when the stby button is pushed on tv or remote
Dec 26, 2009 | Akai LCT2785TA 27 in. LCD Television
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
I have the Philips 27PT6441/37 TV that turns on to the point of hearing sound then instantly turns off and flashes the led 3,2,1.
Plus horizontal lines on top of the screen
Jul 08, 2009 | Philips 27PT6441 27" TV
Shows STBY
STBY means 'Standby'. This is to conserve the batteries. It will come out of standby mode as soon as you press the shutter release button halfway down.
May 29, 2009 | Nikon Speedlight SB-800 TTL Flash
42PF9630A 42
ssb:pnx2015 stby &control
b4e
7j00-5\pnx2015
STBY CPU
1LA0\16MB
X840GA
May 22, 2008 | Philips 42PF9630A 42 in. Plasma Television
My sony FLASHES 4 times
STBY LED flashes
2 times pcb X SUS TEMP (DD CON
3 times pcb Y SUS TEMP (I/O Block)
4 times Center TEMP
5 times Digital 5 volts
6 times PANEL FAIL (PDP)
try unplugging it for a while, from other forums looks like they sent them back to sony for repair
Dec 10, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
