Question about GE Refrigerators
Ge artica side-by- side ice maker fillsup once then stops making ice? whats up?
  • 166 Answers
Older ice makers have a wire bail that comes down and acuates a micro switch that tells the ice maker to stop cycling when the pan is full. Sometimes the micro switch can get froze up. Lift the wire bail up and down an listen for the switch to click. If this switch is not clicking, it may be froze up. Also make sure the wire bail is going completely down after the ice maker cycles.
Posted on Nov 15, 2009
  • 126 Answers
YOU NEED TO HAVE YOUR ICE MAKER CHECKED AND SERVICED BY A TECH.THE TIMER MOTOR INSIDE THE ICE MAKER COULD BE STICKING.
GOODLUCK.
MOHAMED
Posted on Sep 19, 2008
Our ice maker is making a constant clicking noise like the arm is out of the gear and the gears keep slipping
The gears slipping is very possible in this case. Problem is with that Ice Maker there are no replaceable parts. When used a lot and a simple failure of one of the six stages of operation the ice could have become stuck while the heater that warms the cube slots may have failed causing the motor to be doing exactly just like you said. There are cheaper ice makers out there but I have lost my confidence in what they sell on e-bay. The price is cheaper there but counterfeit or factory rejects appliance parts is mostly what they sell. Click Here for your part=> WR30X10093 Electronic Ice Maker
GE
ARTICA PROFILE TECHNICAL INFORMATION
Here is a link to a Service Manual=>
PSS26MSRSS
and if I missed something please let me know, Thanks, Sea Breeze
Jan 11, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
Ge profile artica constantly knocking
Broken internal motor mounts in compresser.
Jun 03, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
Aug 18, 2009 | GE Refrigerators
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Artica PSS29NGNA no ice is being / no water flow on ice side
It is possible the water control valve on the back of the refrigerator is defective. When the thermostat in the ice maker tells the water control valve to ope after dumping the ice. Try filling the ice maker with tap water and let it freeze and cycle one time. It is also possible that the fill tube for the ice maker has frozen shut because of the slow continious flow of a leaking water control valve. You can try to clear the ice with a hair dryer, but if the control valve continues to let water buy will have another damaged ice maker. The part number for the water control valve is WR57X10032 and you can enter parts numbers and model numbers on the search feature at the link below. Let me know how thing are and if you were able to get this under control, I am here to help if you like, sorry I just today saw your post, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | GE Refrigerators
Water spout to ice maker frozen
defrost ice maker fill tube and replace duel water valve valve for i/m is sepping water
Dec 14, 2008 | GE Profile Arctica Stainless Steel Top...
Ice maker doesn't make enough ice
Try turning the thermostat all the way down if it works you can back it down.
Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
Ice maker broken
check to make sure the arm or what ever controls the cubes isn't stuck closed or the inlet to the maker isnt' got some restriction
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
