Brother mfc 215c will not print black and white when ink black full
And the colors are empty.in the pref i marked to print grayscale but still will not print.pl's help
br
Div
  • lady_tab Sep 23, 2008
    My black ink Cartridge is full my color is empty. The printer will not let me print even in black and white.
SOURCE: brother mfc-215c unable to clean?
What is machine error 26?
Posted on Dec 13, 2007
  • 26 Answers
SOURCE: Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
Posted on Dec 15, 2007
Mix-it-up
  • 832 Answers
SOURCE: Is there a way to get Brother MFC-240C to only use black ink cartridge?
Theres a simple trick to cheat the machine.
BUT
you will definitly destroy the printhead when doing so for a longer periode!
You have to put some black adhesive tape around the middle part where you can see this black palstic flag inside the cart. This flag signals the printer that the cart is insert and later on when the ink is down to give the waring: near empty.
I do give you the advice to do another but saver cheating:
You can refill the cart with a mixture of 8 ml destill water and 3ml 85%-Glycerol (e. g. Glycerin alc. which can be bought at a drugstore for a few cents). Shake the mixture well (within the syringe) before refilling the cart.
See pics here how to do so (LC1000):
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
(brother has changed the construction of the carts! If you can see a plastic quad in the middle of the cart, you have to drill the hole just behind the air valve (white plastic looking out of the cart)
Posted on Feb 24, 2008
Mix-it-up
  • 832 Answers
@artkoy:
There is no Error 10 within the maintenance of the printer!
An error starting with 10 (and two more digits) belongs to the communication device (fax).
Plz check again what two digit error you have and post again.
@peter:
you need a new waist ink absorber. plz check the forum for unable to clean or error 46. Its explained many times.
Posted on Mar 30, 2008
kakee
  • 1269 Answers
SOURCE: unable to clean brother MFC 215c
You can try to press the power button for 30 secs, unplug the power for 10s while holding the power, plug the power back in and wait for 10s then release it.
Posted on Jul 26, 2008
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
How come my printer wont let me print pictures without yellow ink if there is no yellow pictures??
All printers require that all inks are to be full or not empty before it can print your document or print your pictures. So what i can suggest for you to purchase a new set of ink cartridges or have a refill if its available. You can also choose the black and white option or grayscale but i think your pictures have different color aside from black and white so it getting a refill would be the best option. Hope i was able to help you with your problem. Have a great day
May 17, 2011 | Brother MFC 420CN All-In-One InkJet...
I want to print in just back and white, but my printer wont do it.
In order to print in Black and White using grayscale, you will need to adjust the printing preferences within the driver. To change the printer properties complete the following steps:
1. Open the Printers Folder:
  • Windows 2000: Click Start => Settings => Printers.
  • Windows XP: Click Start => Printers and Faxes.
  • Windows Vista: Click the Start button => Control Panel => Hardware and Sound => Printers.
  • Windows 7: Click the Start button => Devices and Printers.
2. Right click on the Brother printer driver and left click Printing Preferences.
3. Click the Advanced tab.
4. Select Grayscale.
5. Click APPLY => OK. Your printer will now print in grayscale.
Oct 26, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Can my brothers printer work only on black ink (MFC 465 CN)
I am afraid you cannot print if (any) one of the cartridges is empty. Here is a screen capture from the properties of my MFC. At the bottom of the picture it says in French : Le MFC arrêtera l'impression Couleur/échelle de gris lorsqu'une ou plus des cartouches d'encre sera vide.
What it say in English is as follows: The MFC will stop printing in Color/Gray scale when one or more of the ink cartidges is empty.
Open the properties of the MFC. Under "Advanced" Tab Click the Printing Defaults at the bottom left. At the bottom of the window that pops up you will see the information that I translated for You.
Jun 30, 2010 | Brother MFC295CNAll-In-One InkJet Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Out of color ink; won't print black and white.
The printer will need the colour ink to be replaced otherwise it will not print at all. You can try pressing the Start/Reset button but this will most likely not work and the only way forward is to have a colour cartridge with ink in it even though you may never use it!
Oct 07, 2009 | Brother MFC-465CN InkJet Printer
I'm out of magenta ink and want to print in black and white. If I select grayscale, I still can't print.
Please look at the following link, it will explain as to why you cannot print when just one color is empty.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000009533&Sympt=Why+can%27t+I+print+anything+if+only+one+of+the+ink+cartridges+are+empty%3f&Model=1230&ProductGroup=5&ProductID=
Aug 02, 2009 | Brother MFC-465CN InkJet Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 215C :yellow and red refuse to print
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 12, 2008 | Brother Multi-Function Center® MFC-215C...
Brother 210C One colour cartridge empty, want to print a black and white fax
Yes, if you dont need the color anymore in future:
You can cheat with empty c/y/m carts by sticking some dark but very thin adhesive tape around the nose (see picture).
After that the printer logic expects the c/y/m carts always as full.
But you cant print any colors within the next 2 weeks anymore because air will dry out the print head (and destroy the color nozzels)!
See brother homepage for instructions on how to print in grayscale only!
Jan 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
117 people viewed this question
jasbo
jasbo
