Question about Whirlpool Dryers
Whirlpool duet wiring diagram - Whirlpool Dryers
  • 1,028 Answers
Remove bottom panel ck on back side or possibly taped to a side wall
Posted on Sep 20, 2008
Hi, I cant tell where all the wires go on the cycle knob of my whirlpool leq5000kqo
Posted on Sep 10, 2009
Wh. duet dryer. the display just flashes when i try to run it . manual sasy chech the door but it seems fine
Posted on Mar 02, 2009
I need the wiring diagram for the heater for the Whirlpool Duet dryer
need a model # very simple diagram 6 wire on most you tube may have a video make your life simpler
Nov 20, 2016 | Whirlpool Dryers
wiring diagrams are difficult to get unless they are released by the company itself sir.
so we cant assure you of getting one.
bu we wil try our best to get you one.
Jun 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer comes up with error f6
The F6 error on a Whirlpool Duet means that the control unit doesn't know the drum RPM speed during the spin cycle. It occurs with a number of problems. The problem could be with the MCU (motor control unit) or the wiring between the motor and the MCU. Next you should check the wiring between the MCU and the CCU (main clock). A problem with the door lock or that wiring could also cause the issue. Finally, the bearing on which the drum spins is bad.
The MCU is the most likely faulty part unless you find a wiring problem. (The wiring harness has a number of small wires connected to it; it's not uncommon for one wire in the group to break while the rest are intact.) Inside the washer's front panel, there should be a wiring diagram with additional information on some diagnostic steps.
If you can't easily spin the drum by hand, then the bearing is a likely suspect.
I hope this helps.
Oct 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer said to not pump when given to me.found the two red wires coming from the motor to harness chewed in two . need to know or see wiring diagram.also i get power to controls can not get door to open.i...
The wires should be color coded with a stripe on one or the other reconnect them with the dryer unplugged then plug the dryer in to see if the door will unlock. If it foes not then wait 5 minutes for it to cycle then try.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We lost the wiring diagram for the dryer and removed the heating element from it to get a new one. Now we can not seem to install in right because of wire placement any help would be appreciated. it is a...
From what I can tell you should be only dealing with two wires. The element should be slid, coils up, into the metal sleeve in the bottom right and the wires should connect to the prongs. If your wires arent reaching then you may need to splice some more wire in or replace the wire with a longer one.
Dec 12, 2009 | Whirlpool Dryers
Can I get pictures/diagrams and instructions on removing the mcu board(duet ghwn150pw3) to check out f 06 error? Thanks
Please see the following Whirlpool Service Manual for the Duet Washer.$FILE/Duet%20Job%20Aid.pdf
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer gew9250plo dryer will not turn on
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram heaver red wire for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Schematics needed!retrieveModelDetails.action?modelNumber=GGW9250PL0&productCategoryId=0151200&brandId=1198&method:retrieveModelDetails=x
This link shows the blow ups for the different area's of the machine. The schematic would just give you a wiring diagram, but if you need that as well, remove the 2 1/4" screws on the top panel towards the rear. Slide the top panel towards the rear and lift up on it. Once the top is out of the way, you should find a schematic on the right hand side panel. If it is not there (as with some duet models), remove the lower front panel (2 1/4" screws along the bottom of the panel) and the schematics will be attached to the inside of the panel itself.
Jul 04, 2008 | Whirlpool GHW9400 Duet Washer
Dryers Logo
2,127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
