Question about Motorola Cell Phones
I have Razr v3 and battery will not charge, nor will usb conect to PC. If I put fresh battery in it works. Just wont charge in phone. Any tips? Stu
  • sgs14220 Sep 30, 2008
    I have the same problem. mine charged fine this morning. then a couple of hours later i tried to charge and it says "unable to charge"
    Brigadier General:
  • 7,752 Answers
Try cleaning the USB contacts on the phone or take the phone into a mobile shop and have it service and tested there.
Posted on Sep 19, 2008
Razr v3 drained battery charging
the desk top charger wont be working for your device and I suggest you to replace the battery on to another mobile phone and try charging it
Dec 26, 2008 | Motorola Mobility RAZR V3
How to conect razr v3 to my pc???
you need to install the usb drivers for the phone ....go to 4shared.com
Dec 14, 2008 | Motorola Mobility RAZR V3
Motorola razr v3
just conect one port of the cable to p c and other to phone.the taskbar of p c will show ur phone motorola razr v3 conected.than just go to my computer.there u will see "removeble disk".this is ur phones memory.just copy the music frm ur p c disk and paste into it.than just remove ur phone and u will get the music in ur phone.just enjoy it.
Jun 28, 2008 | Motorola Mobility RAZR V3
Razr v3 wont charge
Dear jayhawk9977,
Since the AC is fine (tested) then the phone is probably faulty at the Mini-USB connector. Please check if there is play at this point as a broken (damaged that is) connector will not perform any function. (Test is as well with your handsfree if any) If there is no audio at this point 99% is the connector.
Surely the pins that are used are not the same for charging/handsfree but you can get an idea if the problem is bigger than thought initially.
Problematic batteries can also lead to non charging. 3.6-3.7V (+0.3V) is nominal voltage that the battery works. (if you have a multimeter please test it as well)
Many regards
Please rate this solution if you found it useful.
Apr 02, 2008 | Motorola Mobility RAZR V3
V3 battery
you need to get a proper battery
Dec 30, 2007 | Motorola Mobility RAZR V3
Moto Razr V3 won't connect to my computer
You need to download the usb Drivers fom motorola and get mobile phone tools software
Dec 06, 2007 | Motorola Mobility RAZR V3
V3 Razr
It's the phone itself that needs to be fixed. Buyer beware as they say about Ebay. There are cheap repair shops around depending on where you live. No more than $50. Might have to call around to fid one.
Aug 18, 2007 | Motorola Mobility RAZR V3
V3 Razr is dead, wont charge
take it to a local cell phone dealer and see what they say. most likley bad charger or bad connections.
Jul 08, 2007 | Motorola Mobility RAZR V3
Phone is dead wont take charge
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
Feb 24, 2007 | Motorola Mobility RAZR V3
USB Cable and charging problems
Try checking the usb cable. Some usb cables aren't made so you can charge your phone. Believe it or not but usually the cheaper cables are the ones that work for charging my motorola razr v3 phone. If that doesn't work, check to see if you didn't mess up the interface when you plugged into the phone.
Dec 08, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
29 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
