Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson animal loses suction when I let the handle down from the upright position to use, I've cleaned the foam filter, and the plastic filter holder and dried thoroughly, removed and cleared the right side U-bend, and the center, rear U-bend access, also made sure nothing was in the way of the beater bar. Any thoughts? thanks. lorri
Is the noise a loud screaming or a grinding/vibration? The screaming is an air flow problem and you'll want to check your hoses are clear and all the seals are tight. The grinding is an issue with the roller/belt/clutch/motor/housing. From what I'm reading, both problems are common on the Dyson animal.
Posted on Sep 20, 2008
Dyson DC 25 power shuts off in upright position
To clarify, do you mean the suction and brush motion shut off in the upright position, or that the entire unit shuts off?
If the latter, most Dyson uprights shut off the brush unit in the full upright position and shunt the suction into the handle for use with the accessories. There is also an on/off for the brush, next to the main power button for the DC25. If it's off ( or stuck that way), no brush motion. The manual also notes, 'for use, turn on power and click the foot pedal in back to recline the unit.' (Link to manual here:
http://www.dyson.com/medialibrary/files/dyson/support/downloads/uk/floorcare/manuals/DC25_Manual.pdf See Page 8). The
'High Reach Cleaning' section also notes that the brush bar won't rotate when the vacuum is in the full upright position.
If you are completely losing power, the manual notes that the unit will shut off if the bar is jammed, or if there is a significant line blockage that makes the motor overheat. If this is happening, check the accessory line in the handle for blockage.
Good Luck :-)
Jul 11, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do I restore suction?
Cheap plastic parts. trade it in on a good vacuum like panasonic
Dec 31, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal: Loses suction when in the upright postion and I am using the wand. I have cleaned the top spongy filter. It sort of 'blows' out of the top of the cylinder if that makes sens
Hi Sharon,
I'm sorry to hear you're having difficulties with your DC14. If the machine doesn't seem to be picking up as well as usual through the wand, this may be due to a blockage in the wand, hose or U-bend. The easiest way to check for this is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc14/dc14-origin-iron/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
Although I note you've cleaned the filter, you might want to check you've washed it as shown in the video below - in normal use, this should be done at least once every 3-6 months. Wash both parts of the filter in cold water without detergent, and allow at least 12 hours for it to dry before replacing it.
This should resolve your issue, but for any further assistance, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
Feb 07, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
It is not picking up from the carpet--the exhaust air is coming out the bottom back and not from the top handle--I was not the last to use the vacuum--I think the housekeeper used the handle hose and the...
Sorry to hear your DC28 Animal is not picking up. To check everything is correct with your machine, please ensure the filters are clean, and the cleaner is free of blockages. This guide from the Support section of our website shows the easiest way to do this:
http://www.dyson.com/support/help.asp?article=1456&product=DC28-ANIMAL
Please note the motor exhaust, where filtered air is returned to the room, is located beneath the clear bin. Exhaust air will never come out of the top of the handle.
If you've checked the machine for obstructions and are still having problems with the performance, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com , so we can provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 24, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
No suction. upright position shuts off unit. Turning off brush bar shuts off unit. will only run in floor position but has no suction. no clogs found.
From what you've described, it sounds as though you may need to wash the filter. This video guide from the Support section of our website shows the correct way to do this:
http://www.dyson.com/support/help.asp?article=1463&product=DC17-ANIMAL
Although you've found no blockages, it's definitely worth checking again to ensure nothing has been missed. This simple step-by-step walkthrough shows all the areas you should inspect:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
If you've followed these steps and are still experiencing difficulties, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com. One of our experts will run through some troubleshooting over the phone, and provide the assistance you need.
Kind regards,
Jack
Jul 23, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson D17 won't work while upright.
check and make sure you have the gasket installed correctly that goes on the center of the cyclone and seals against the canister trap door. If this is backwards, you can lose a lot of suction and it will plug your permanent filter quickly.
Sep 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC7 full Kit, with one belt does not get suction to head.
Not absolutely sure about this, so your feedback will be very welcome.
What follows applies to the DC14, which I think is similar in this respect:
Stand behind the machine, holding the handle at a 45 degree angle. Locate and remove the airway inspection valve (bottom of handle, right side). Where the valve plugs in there is a square plastic moulding that should slide up and down. Snap that square plastic piece up towards the ceiling. After it snaps into place, the machine should stand upright.
Good luck, and please let me know how you get on!
Mar 21, 2009 | Dyson DC07 All Floors Bagless Upright...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC 14 animal bagless--unable to use wand
Hi.
Try these tests & tell me the results.
Remove the hose & wand completely from the machine it unclips at the bottom of the back.
Leave handle in full upright position & switch on do you still get the sound of something blocked ?
If yes remove the (U) shaped inspection port again at bottom back of machine now repeat last test what happens ?
Please reply with your answers.
http://dysonmanuals.llc.nu/index.htm
Chris.
May 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
262 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
