Question about i-mate PDA2k Pocket PC
Imate pda 2k touch screen not functioning
I got imate pda 2k repaired. The technical person in the shop proclaim that he changed the touch pad. The touch screen work nicely for that particular day itself. Touch screen is not functioning now. It happen twice.
SOURCE: I mate Jamin
I have had the same problem with my jamin and most of times soft resetting it via the button at bottom solves it. If it happens regularly, you might want to hard reset it. please make sure you backup your data and settings etc
Posted on Oct 12, 2007
  • 490 Answers
SOURCE: Touch Screen not working and fequently gives trouble
1st take back up of the data then  do softreset then see or try to reduce some data from ur mobile then try else visit service center
Gizmo1
Posted on Oct 22, 2007
  • 12 Answers
SOURCE: imate jasjam
I would look at some third party applications that clear up the memory while you are on the PDA / JAM. You can also go into the settings function, memory and view running programs.
One of the earlier version flaws of Windows 2003 is that it does not offer a shut down menu on the Today Screen. There are quite a few freeware applications that allow you to shut down running programs. I tend to run one or two programs - maximum at a time. This is not a laptop. I find my touch screen unresponsive if too much memory is in use. It's not really the touch screen but that the computer can't follow my commands, almost like an old 283 or 386 computer.
Take a look for these tool bar/memory manager programs before sending out to service in Mumbai.
Posted on Dec 31, 2007
SOURCE: Imate jasmin battery not charging
make a reset...
Posted on Jan 01, 2008
SOURCE: Imate JAMA
How to change language from Arabic to English in i-mate JAMA?
Posted on Apr 27, 2008
My imate jamin phone touch screen had broken, whether it is repairable, if repairable what is the cost. Kindly reply me
To be really honest, i mate services are the worst in most of the Asian countries. Even though you would find a Service Center, they might charge you so many bucks. Still, no guarantee. I am taking into consideration majority of people who have purchase i mate.
It usually cost $35 + Labour charges.
You can calculate in your currency.
Thanks.
Jun 16, 2009 | Griffin Technology iMate - Universal ADB...
Screen toutch
hi thanks for using fixya!
I suggest you should contact your nearest Imate service center in your area in regard with your touch screen.
regards!
Jun 06, 2009 | i-mate JAM Pocket PC
IMATE JAMA touch screen not working
hi thanks for using fixya!!
I am sad that the Imate Jama is not providing much use to you. However, it will be a useful one if you are going to explore its functionalities.
Anyhow, in regard with your problem, we cannot do anything with it, the only recommendation I could tell you is to bring your PDA to a service technician to further check the hardware error of it especially the touch screen does not working properly.
Regards!
May 21, 2009 | i-mate JAM Pocket PC
I have an iMate JamIn Phone/PDA. The screen is badly out of allignment and re-alligning does not help. Any solutions, please???
If you have already tried the re-aligning of the touch screen, and you have failed. It is better to bring your Imate to a service tech, to check the software details of your pda.
Or if you want, try to reset it or master clear so that it will go back to its factory default.
Thanks! please rate my solution positively!
Mar 17, 2009 | i-mate JAMin Smartphone
Imate jamin mobile
You may install programs to your Imate by using ActiveSync, just install first your activesync to you computer and then after the successull installation of the Activesync, connect your Imate to your pc using usb cable, then click activesync from your pc then it will automatically prompt you for your preferred activesync settings.
Then on installing programs, if you have the program in you pc just click the program to run and then it will automatically install it to your pc and PDA, but if you want it to install directly to your PDA, you should copy the program using activesync to your PDA, just save the prorgam file to the internal memory or to the sd memory and then from your PDA you may install it smooth and easy.
If you do not the activesync you may download Here
If you need further, let me know!
Please rate my simple solution positively! thanks!
Jan 31, 2009 | i-mate JAMin Smartphone
From where i can download imate PDAL USB driver
download it from limewire and almost all pda application works on microsoft pda...i.e   imate ,o2 ,htc and all which support microsofts
Jan 23, 2009 | i-mate PDAL Pocket PC
Unlock the imate jam
you can register clubimate.com and download generic rom for imate jam. and flash it with that rom.
But, it is risky. i won't take any gurantee.
Jul 18, 2008 | i-mate JAM Pocket PC
Jasjam sceen go white
i had the same problem with my imate. i had to send it back for repair, They said that it needed a software upgrade. Don't know if that was true or not but it did fix it.
Dec 13, 2007 | Griffin Technology iMate - Universal ADB...
Wet screen IMate pocket PC
* completely turn off the device * remove the battery * take a cotton cloth * hit it for some time, not very hot * press your mobiles screen with the cotton for 2/3 min, do it for 4/5 times, if no luck escalate it to vendor and don't tell them it is because of water drop otherwise warranty will be void. thanks Arun
Mar 07, 2007 | Griffin Technology iMate - Universal ADB...
i-mate PDA2k Pocket PC Logo
174 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
