I have forgotten the password that i used when opening my account. please assist. thank you phill rogers
    Novelist:
  • 84 Answers
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Posted on May 13, 2009
    Guru:
  • 77 Answers
You can remove the password. If you didn't reset the default password,try to log in in safe mode and then let the defualt admin password blank and you will enter.
If you can't, follow these tips.
http://resetlostwindowspassword.blogspot.com/2010/11/how-do-you-recover-your-lost-windows.html
Posted on Dec 21, 2010
    Guru:
  • 108 Answers
If you can not find the password you must reset the password. You just google related keywords like "windows password unlocker" , there will be a lot of related result on Internet.
Posted on May 14, 2009
    Problem Solver:
  • 13 Answers
Long time ago , I confronted with the similar problem. Finally , my friend Jane introduce the Windows password Reset.It help me access windows. It's worth a try!
http://www.resetwindowspassword.com
Posted on Apr 24, 2009
    Sergeant:
  • 241 Answers
Hey RYAN If you still need help login in on here let me know i have not seen you around....
Thanks
jayson
Posted on Sep 27, 2008
    Sergeant:
  • 300 Answers
Log on as an administrator to reset the password loadTOCNode(2, 'whattotry');
Windows XP Home Edition or Windows XP Professional loadTOCNode(3, 'whattotry'); 1. Log on as an administrator. a. Restart the computer. b. Press CTRL+ALT+DELETE two times, and then type the name of the administrator user account. c. In the Password box, type the administrator password, and then click OK.
Note If the administrator password is set to a blank password, do not type a password before you click OK. 2. Reset the password. a. Click Start, click Run, type control userpasswords2, and then click OK. b. Click the name of the user account that you want to reset the password for, and then click Reset Password. c. Type a new password in the New password box, and then type the password again in the Confirm new password box, and then click OK. d. Restart the computer, and then try to log on to Windows XP again.
Windows XP Home Edition or Windows XP Professional in a workgroup loadTOCNode(3, 'whattotry'); 1. Log on as an administrator. a. Restart the computer, and then after the Power On Self Test (POST), press the F8 key. b. On the Windows Advanced Options menu, use the arrow keys to select Safe Mode, and then press ENTER. c. Select Microsoft Windows XP edition, and then press ENTER.
Note In this step, edition represents the correct Windows edition. d. On the To begin, click your user name screen, click Administrator, and then type the administrator password. e. Press ENTER, and then click Yes. 2. Reset the password. a. Click Start, and then click Control Panel. b. Click User Accounts, and then click the name of the user account that you want to reset the password for. c. Click Change the Password, and then type a new password. Note If you do not want to use a password, click Remove password, and then continue to step "e." d. Click Change Password. e. Restart the computer, and then try to log on to Windows XP again.
Windows XP Professional in a domain loadTOCNode(3, 'whattotry'); 1. Log on as an administrator. a. In the Welcome to Windows dialog box, press CTRL+ALT+DELETE, and then type the name of the administrator user account. b. In the Password box, type the administrator password, and then click OK.
Note If the administrator password is set to a blank password, do not type a password before you click OK. 2. Reset the password. a. Click Start, click Run, type compmgmt.msc, and then click OK. b. In the Computer Management (Local) dialog box, expand Local Users and Groups. c. Click the Users folder, and then right-click the user account that you want to reset the password for. d. Click Set Password, and then click Proceed. e. Type a new password in the New password box, type the password again in the Confirm password box, and then click OK two times. f. Restart the computer, and then try to log into Windows XP again.
Thank you for choosing FixYa!
Az.
Posted on Sep 19, 2008
    Problem Solver:
  • 13 Answers
You have to reinstall tje wndows copy or try typind username as admin and password as admin
Password forgotten?
You can reset your forgotten password which in return will hopefully help you open your Gmail account.
Open the following page and follow the instructions:
https://www.google.com/accounts/recovery/
Hope that helps!
Mar 25, 2016 | Computers & Internet
I've forgotten all of my info on my account and i need to start afresh
If you've forgotten your Google Account password or are receiving the message 'Username and password do not match' when you try to sign in to your Google Account, please visit the password-assistance page and enter your username.
Account username:
  • For Google Accounts without Gmail: the full email address you used to create your account.
  • For Google Accounts with Gmail: everything that appears before '@gmail.com'
Once you've submitted your username, type the letters in the distorted picture in the appropriate field, and click Submit. Depending on your Google Account, you'll be prompted with one of the following options:
We'll send a message to the address registered as your Google Account username. This message contains instructions to reset your password.
  • If you have an alternate email address listed on your Google Account, we'll send a message at that address containing instructions to reset your password.
  • If you don't have an alternate email address listed on your Google Account, and you have been trying to sign in to your account, please stop trying to sign in for 24 hours. After 24 hours, visit the password-assistance page and enter your username. You should now be able to reset your password by answering your security question. If you did not create a security question or do not remember the correct answer, please fill out our form so that we may assist you.
Sep 06, 2014 | Google Chrome
I need help to set up micrsoft outlook. My internet provider is Rogers please assist. thanks
Launch Microsoft Office Outlook 2007.
Click Tools on the top menu and click Account Settings.
Select the E-mail tab, and then click New.
Check Manually configure server settings or additional server types, and then click Next.
Select Internet E-mail and click Next.
nter the Rogers email settings as follows: Your Name Your email address Account type : POP3 Incoming Mail server : pop.broadband.rogers.com Outgoing Mail server : smtp.broadband.rogers.com User Name : your full Rogers email address (including @rogers.com) Password : Your email password When you are done entering the settings as shown above, click Next.
Click on Outgoing Server tab and check "My outgoing server (SMTP) requires authentication".
Click on the Advanced tab and change the port number of Outgoing server (SMTP) to 587, then click OK to return to the Add new E-mail Account window. On the Add new E-mail Account window click Next.
Click Finish.
Apr 12, 2011 | Computers & Internet
I change my password but i forgot it
Hello and Welcome
You don't worry. If you have forgotten your password then just GO HERE
Follow each step carefully, You will be able to restore your account.
Further assistance i am here to help
Please click on Four thumbs which are given below to this solution "if it is helpful"
THANKS & Keep Using Fixya
Mar 13, 2011 | Facebook Social Network
I need to find out the password for my facebook account.
You will have to contact the Facebook support group. On the login page to Facebook there is a link for forgotten passwords as well as a help link. If you choose the forgotten password link they will send a new password to the email address that you registered with them upon opening your account. You will then be able to login and change your password to whatever you want to use.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 17, 2011 | Computers & Internet
I forget my password
If you have forgotten your password then you have to try to reset it with your security questions which were previously filled by you during creation of your account.
https://edit.india.yahoo.com/forgotroot?done=http%3A%2F%2Frogers.yahoo.com&src=&partner=rogers-acs&intl=ca
You can reset it by going to the above link.
Thanks.
Have a great day.
Dec 03, 2010 | Yahoo Mail
My email ac is blocked due to security reson said by yahoo
Click I can't access my account on yahoo mail page.
Select forgot password. If you forgot your password.
Click on Next.
Enter your ID and code shown below.
Then verify your ID and reset your password.
Note make sure you provide the correct details.
Jul 21, 2010 | Yahoo Mail
I had forgotten my gmail password and the answer for the secrete question because i created this account before three years so i forgotten what was i gave at the time of creating the account i had done all...
I have done the email password recovery for you.Your password has been sent to your yahoo email address.please log in to your yahoo email id and check it out. you should be able to use your email id. But if you are unable to answer the security person, please go to the following link and complete the form so that you can access the account later.
https://www.google.com/support/accounts/bin/request.py?ara=1&hl=en&contact_type=ara&ctx=ara
you should enter the details for your account to be verified.thanks. hope it helped you.regards, venugopal. please rate my solution as helpful.
Feb 17, 2010 | AccessData Password Recovery Tool Kit (ftk...
Computers & Internet Logo
438 people viewed this question
David Payne
David Payne
