Question about Fujitsu ScanSnap Manager
"Failed to initialize the sRGB engine" - ScanSnap won't work at all :(
Originally, I was able to successfully install all of the software bundled with ScanSnap. I absolutely fell in love with the machine. Then at some point I started getting an error message whenever I pressed the green "scan" button: "Failed to initialize the sRGB engine. Please reinstall ScanSnap manager." I have not been able to successfully use the ScanSnap since then. I have uninstalled and re-installed the 5 pieces of software that are bundled with the ScanSnap several times since then, but each time I get the same error message. I contacted the company and they gave me a "clean" utility for uninstalling ScanSnap manager, but that didn't make a difference. I also tried deleting the folders that get left behind after uninstallation as suggested by TMRI. I also went into the registry to delete the "PFU" settings. I am very discouraged -- I desperately want to get this machine worked otherwise it's a very expensive piece of junk. I would be very grateful for any help!
  • 5 more comments
  • flowmom Sep 19, 2008
    By the way, I have another scanner that is working fine. But I just noticed that when I go to Scanners in the Control Panel and go into the ScanSnap properties, it shows that the scanner is "unavailable" even when the USB is plugged in and the power is on.
    I'm sorry, I forgot to mention that I am using Windows XP Home SP2 (installed SP3 after the scanner stopped working). I have ScanSnap model S510 and I bought in in summer 2008.
    Are you asking for the serial number of the ScanSnap?
  • flowmom Sep 25, 2008
    After a lot of persistent bugging, Fujitsu Canada helped me to solve this problem. Under Settings|Control Panel|Scanners and Cameras, the ScanSnap S510 didn't have any Color Profile associated with it. The Fujitsu guy emailed me the "sRGB Color Space Profile" file and I copied it to the correct folder and selected it. Now everything works!! I have no idea why that file was missing.
  • margox22 Oct 13, 2008
    I am having the same problem receiving the "failed to initialize the sRGB engine" message. Can you post the file for others to use.
    I have the S510 model...
    Thank you
  • msayag Nov 09, 2008
    I have the same proble with Windows Vista 32b, how should I do?
    Thanks for help
  • Anonymous Apr 24, 2009
    sam problem
    Problem Solver:
  • 5 Answers
Not download just tell me serial number.
Posted on Sep 19, 2008
I have an IMac with a Fujistsu S1300. I upgraded the harddrive and now the scansnap application does not work. I have tried to re install the scansnap but it always gives the same message" General Error...
There might be a software package that you need to install that you can probably get from the Fujistsu main site. You'll need the drivers for the scanner. I think i've located the correct ones here:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
You'll want to download the proper package. The top one should include the S1300, just make sure you're downloading the correct one. Once downloaded, install, and it should properly function.
Dec 13, 2013 | Fujitsu ScanSnap Manager
Scansnap hardware error 0x00048004
I had this exact same problem. Turned out that I was using the wrong power adapter. Enough power to turn on the scanner lights and connect to the computer, but not enough to actually perform a scan. As soon as I realized I was using the wrong power cord, I switched it up and voila!
Jan 23, 2013 | Fujitsu ScanSnap Manager
I installed ScanSnap on Windows 7 under the administrator account and it works successfully. The problem is with the other non-administrator account. The ScanSnap icon was not installed on the...
OK; after giving up on lousy tech support I got it working after doing the following (not sure if all required, but this is what I did)
1. Gave admin rights to C:\Program Files (x86)\PFU
2. Updated to latest ScanSnap Manager V5.0 L21
3, Copied C:\Users\<admin acct>\AppData\Roaming\PFU directory to C:\Users\All Users
Good luck...
Mar 21, 2010 | Fujitsu ScanSnap Manager
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
Sending E-Mail Failed (0x80004005) - Fujitsu ScanSnap S510
You need to open Internet Explorer and add Thunderbird as your email program. Click Tools > Internet Options > Programs tab > E-mail: Select Mozilla Thunderbird from the drop down.
Jul 19, 2009 | Fujitsu ScanSnap Manager
Problem installing Scansnap S510
This is probably due to the program using the same folder for the new version of the program. Best solution would be to uninstall the new version, uninstall the old version and then reinstall the newset version only.
Running a registry cleaner in between does not harm.
One other thing to try is an uninstall program, but I am not sure that will help.
Jan 21, 2009 | Fujitsu ScanSnap Manager
Error while attempting to install ScanSnap Manager on Win XP Pro
Bypass installation wizard and just run the setup.exe file for ScanSnap Manager. Installation wizard is bugged.
Jan 09, 2009 | Fujitsu ScanSnap Manager
"Failed to initialize the sRGB engine. Please reinstall ScanSnap Manager"
I managed to fix the issue by running a Command Prompt screen and typing the command: sfc /scannow. The system recognized that I had some corrupted files and it repaired them... After a reboot, my ScanSnap S500 is working again...
Nov 09, 2008 | Fujitsu ScanSnap Manager
Driver scansnap
There should not be any problem installing that sofware on that OS and version. My guess is you have a botched (corrupted) install. Try uninstalling if you can otherwise let me know and we'll "clean out the registry." Good luck!
Jul 22, 2008 | Fujitsu ScanSnap Manager
Computers & Internet Logo
3,181 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
