Email Air Air Conditioners fault codes
Can you tell me what the fault code "HO2" on an Airwell Air conditioner means?
  • 6 Answers
SOURCE: where do I find parts for everstar portable air conditioners
I just purchased a 11,000 BTU Everstar from Home Depot. Not sure if it's the same model that you have. Maybe check there? I bet an employee would be willing to open one of the boxes to answer your question. Just tell them you bought it there. :) Or call Everstar, of course. Good luck!
Posted on May 31, 2009
co7196
  • 3433 Answers
SOURCE: Roof Top air conditioner makes too much noise
Hello; Those roof tops can be noisy. Are you able to determine what is causing it? The fan? The A/C pump? Over tume, the vibration isolators that are rubber cushions the pump is mounted on, get weathered and hard and they no longer absorb the vibrations of the running pump. Those are easily chked and changed. The next point of excessive noise is the unit as a whole is tranmitting the combination of all the vibrating parts including its own housing. Here too we have a remedy. The roof unit has a seal between it and the camper roof around the hole it is fitted in. The seal is foam rubber and reasonably thick enougth to serve a purpose more than to seal out water and air. After and over time this seal ends up crushed from the weight of the a/c unit. Then the A/c unit comes in contact and is actually resting on yhe roof with what is now a very flat hard gaske. The roof unit is now vibrating the roof. This is as destructive as it is annoying. Ok? Now let's get rid of 80-90% of the noise. Check and replace compressor vibration isolator mounts. There are 4 bolts holding down the A/C unit. Sccess them from the inside by removing the ceiling trim and cover.There should be one on each corner. Bolts removed, one person push up on the unit and another on top lifting the unit. There are wires going to the unit and those may need to be disconnected. Clean the roof and the a/c where yhe seal goes.You can get a new seal from camping world or rv supply. Have your measurements, Unit make and model when you go.Assembly is just backtracking. On assembly, thinhs to pay attention to are:
Put the new seal on the A/C unit, not on the roof. It takes two people to ligft and set the unit back into the hole and center it in the hole. Don't slide it on the seal. lift it if it hs to be moved or the seal may roll over..
The wiring disconnected earlier must be dealt with and put in place for reconnecting.
Now start the bolts that hold the unit down.
Make sure-- Unit is centered
Wires can be reconnected
The four hold down bolts have their washers.
Someone go topside and verify the seal is properly in place. Measureing the for corners fo even height is one way to ck and looking under the unit is another. Now tighten the four bolts evenly. corner to cross corner. measuring again will help confirn its pulled down evenly. Pull it down no more than 1/4 to 5/16 of the seal thickness. Wire it up and put the trim and plastics back on and light it off. (run it and ck for noise and vibration. NOTE!!! The A/C unit cannot touch any solid part of the roof. Reason it was centered. Always ck the unit before each trip as you would any other psrts on the exterior of the camper. Good Luck Angie.
Posted on Sep 16, 2009
  • 13 Answers
SOURCE: Capacitors and contactors for Goodman air conditioner
I havent had luck in finding a part list for you but have you tried to look at the label on the motor(s) to find the capacitance? Or try on the existing capacitor? Dual caps are usually listed as 35/5uf or 35/5MFD on the actual part. There are only a few variances of contactors for residential systems normally 30-40va single pole single throw (spst) or 30-40va single pole double throw (spdt) singe throw contactors have four contacts for 220v and double throw contactors have two contacts for 220v and a constantly hot leg.
Posted on Oct 26, 2009
co7196
  • 3433 Answers
SOURCE: Samsung Air Conditioner will not turn back on after power Outage
Turn off the circuit breaker and wait 10 mins, then back on.
Turn off all units, wait a about 1/2 hr. See what that does. Also, Turn only one unit on at a time and let it run 5 min before turning on the secon and the same withe third. An what remote island might that be? Good Luck, Ned
Posted on Nov 11, 2009
atocrxr
  • 135 Answers
SOURCE: air conditioner wiring diagrams
What brand of A/C is it? Are you looking for the thermostat wiring? Different Brands use different wiring, but the usual is as follows:
R terminal at furnace is 24 volt Hot
W is the control for the heating cycle
G is used to start the furnace blower
Y is used to start the outdoor A/C
B or X depending on Brand is the 24 volt common
Yellow and B or blue is the other wire that goes to the outdoor unit
If you want more info, I need Brand, and type of unit, gas furnace and A/C, electric furnace and A/C, or is it a heat pump for the outdoor unit?
Hope this helps./
Sincerely,
Paul Gibson
Posted on Apr 01, 2010
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
Living in Burlinjgton Ontario Canada. Looking for owners manual. How can I get one?
Henry, unfortunately Fedders as you knew them is now out of business, A company by the name or Airwell bought parts and manufacturing and it's now call Airwell-Fedders. You particular model is no longer available. However, if you contact Airwell-Fedders Customer Service 866-829-2440 or email them customerservice@airwell-fedders.com they should be able to help you with the manual.
Good luck. I hope this helped you.
May 24, 2011 | Fedders SFPEB08F2B Air Conditioner
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
Model 30gx faults code
Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
Shastalaker7
PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
Mar 16, 2010 | Carrier 38CKC036 Air Conditioner
I have a sanyo duted split and comes up with code ho2..
have a certified tec try to unstick compressor likely new compressor
Jun 15, 2009 | Sanyo CMH2472 Air Conditioner
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Heating & Cooling Logo
923 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
