Question about Garmin GPS
Garmin Oregon 400t. The screen is very light outside when the ambient light is overcaste. Is there an adjustment or a way to make the screen brighter?
4 Suggested Answers
  • 121 Answers
SOURCE: wrong language on garmin oregon 400t
look up the words in the dictionary
Posted on May 03, 2009
SOURCE: I have a garmin oregon
Make sure you have your base map enabled. Go to Setup | Map | Map Information | Select your base map and enable it.
Posted on Jun 25, 2009
SOURCE: Accuracy issue with Garmin Oregon 400t
Hi rodieeee
Did you ever find out where was the problem? I just got a 400T and indeed accuracy is horrible!
Posted on Jan 06, 2010
SOURCE: language setting wrong on Garmin Oregon 400t
1) Go into setup. This is the icon that looks like a wrench.
2) Use the arrow buttons to scroll up to the top of the list
3) Select the second item down (GPS will be the first item)
4) Scroll to the top and English should be at the top of the list.
Posted on Aug 30, 2010
Canot delete geocaches
Connect to a computer (via USB), browse to the "Garmin/GPX" folder and delete the gpx file(s).
Jan 28, 2014 | Garmin Oregon 400t Handheld GPS Receiver
Garmin oregon 450t screen blacked out
Replace the batteries with fresh ones.
Connect the Oregon to the computer and run the Garmin WebUpdater to load or reload the latest software to fix any bugs and issues.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Feb 07, 2012 | Garmin Oregon 400t Handheld GPS Receiver
My Garmin Colorado won't go past load maps....I tried new batteries and still no difference....please help before I throw it against the wall
I had an Oregon 200 and i had the same problem. It ended up the brightness was turn all the way off and then i locked it.
May 07, 2011 | Garmin Colorado 400t
Have a Garmin Oregon 400t. It does not want to recognise maps stored on the SD card. If I connect the Garmin to computer, I can read the files on the SD card but when I look to select the maps, they are...
Memory Maps are for PDA's only, not for Garmin GPS units. If you purchased these from Memory Map, contact the company and request a refund due to hardware incompatibility. Maps for the Oregon are from Garmin (purchase) or Ibycus (free).
http://www.ibycus.com/ibycustopo/
Jun 29, 2009 | Garmin Oregon 400t Handheld GPS Receiver
Deleted or corrupted map files on garmin 400t
go to http://www.garmin.com , connect your device with the USB cable , install the connector , go to maps , click update , good luck
Jun 27, 2009 | Garmin Oregon 400t Handheld GPS Receiver
Hi rodieeee
Jun 25, 2009 | Garmin Oregon 400t Handheld GPS Receiver
Language setting wrong on Garmin Oregon 400t
May 03, 2009 | Garmin Oregon 400t Handheld GPS Receiver
Wrong language on garmin oregon 400t
I called Garmin for this very same reason. The answer is; while your GPS is off place your index finger in the upper left of the screen, turn on the GPS, a screen will come up and ask if you want to clear the GPS (or something to that effect), say yes. (Yes is the top button) Then you can choose english. YAY!
Rin
May 03, 2009 | Garmin StreetPilot 2720 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
